propane Posted December 19, 2011 Share Posted December 19, 2011 (edited) Cant remember if you said the PCV was checked or cleaned/ replaced (few $)? Old school test (not sure its accurate today w/ modern emission system) was to shake the valve, if it rattled- was OK- I did a so so cleaning of mine. Maybe the hose is working ok, a spray down of WD 40 at its juncture(s) could tell if leaking. (idle change or surge) EDIT: You did change PCV, if the hose isn't drawing in air... Edited December 19, 2011 by propane Link to comment Share on other sites More sharing options...
heartless Posted December 19, 2011 Author Share Posted December 19, 2011 PCV was replaced - altho the old one did still rattle and fairly smoothly, too, despite all the gunk on the outer edges. i did find that using a heat gun breifly (and carefully) on the hose did soften it up enough to make reinstalling a little easier, but dang - when it was cold, it was hard as a rock. Link to comment Share on other sites More sharing options...
propane Posted December 19, 2011 Share Posted December 19, 2011 (edited) following is the link to idle air screw (early legacy) legacy 777 post looks like it could carbon up- an easy clean or back out a fraction of turn http://www.ultimatesubaru.org/forum/showthread.php?t=42733 Edited December 19, 2011 by propane EDIT; Link to comment Share on other sites More sharing options...
heartless Posted December 19, 2011 Author Share Posted December 19, 2011 idle level (when it isnt surging) is perfect - according to FSM, it should be about 700 RPM (+/- a little) for the automatic - i believe the manual version is just a little higher - so I will not be messing with any of the "adjustment" screws. cold start to full operating temp (no driving) it is dead on - sitting at a traffic light, in gear, it is dead on - sitting in my driveway after driving, in gear - it is also dead on - but the second i put it in "park" after having driven somewhere - that is when the surging starts. previously - i could not get it to settle into the 700 RPM range and stay there no matter how hard i tried, now I can (or at least i did last night when i got home - havent driven it enough yet to know if it will do this consistently or not) Link to comment Share on other sites More sharing options...
propane Posted December 19, 2011 Share Posted December 19, 2011 thats good idea not to change factory settings- those w/ paint - maybe the ECU has to relearn , and the idle RPM sounds about right, as per under hood sticker, autos are the higher one for the benefit of the torque converter, good luck Link to comment Share on other sites More sharing options...
heartless Posted December 25, 2011 Author Share Posted December 25, 2011 just a little update on this one - the ECU is slowly "relearning" the idle curve and the warm idle in park is gradually getting smoother - still wants to wander just a little when initially stopping & putting in park, but it smooths out much faster now I may force the issue by doing an ECU reset - but for the moment, it is much better than it was - would really like to get some of the bigger hoses replaced (primarily PCV system hoses) but cant seem to find those available for purchase anywhere - can someone point me in the right direction??? was told heater hose was not a suitable replacement - am open to other suggestions - 21 yr old hoses are getting pretty hard and not sealing very well... Link to comment Share on other sites More sharing options...
heartless Posted February 6, 2012 Author Share Posted February 6, 2012 well - phooey - still having surging issues once warmed up more than a month later.... again I ask... would really like to get some of the bigger hoses replaced (primarily PCV system hoses) but cant seem to find those available for purchase anywhere - can someone point me in the right direction??? was told heater hose was not a suitable replacement - am open to other suggestions - 21 yr old hoses are getting pretty hard and not sealing very well... for those that dont want to take the time to read the whole thread... 1990 Legacy LS, AWD, Automatic - now has 222K on the clock have already replaced: IAC valve from a lower mileage car that was a known runner - cleaned out before installing Coolant temp sensor all the smaller vacuum lines Radiator replaced recently and filled with fresh fluids, system burped PCV valve (larger hoses need replacing - see above) MAF sensor (from the same car as the IAC valve) oh yeah - O2 sensor was replaced last year... anyone have any other thoughts, suggestions, comments???????? Link to comment Share on other sites More sharing options...
