Justy drive flange
Hello, looking for a front drive flange, or hub for my '90 Justy, all the power stripped out the spline (I had a problem with the conical washer), also need the conical washer and the main nut. Not looking for a freebie, just need to get this car back on the road. Apparently an '88 won't fit. Thanks!
Got the nut and the washer, I am still looking for the flange. It's somewhere in my garage. It may be hid inside the Justy, which would make it a tougher find. But I will let you know when I find it. Mine is for 4wd with 13 inch wheels.
Matthew Bos
