  • 4 weeks later...
Generally I've been going with Outback struts and springs. I've done that on a '96 and a '94 and it is a pretty simple installation. Forester struts I have not tried; might need the corresponding Forester upper spring seat if the upper diameter is smaller like on some Imprezas. Then I use one fastcam bolt in the rear to get camber adjustment, and sometimes need to add one in the front as well if the stock bolt alone doesn't allow enough adjustment.
