evilspawn666 Posted December 16, 2011 Share Posted December 16, 2011 I hope I'm not wasting anyones time on an issue that might have already been discussed in another thread if so let me know which one to read. Driving my car on freeway at a consistent 60mph and with no indication the motor just shut off. Tried restarting with no luck, gave up and had it towed. Checked the distributor and rotor doesnt move when trying to start. Any help is appreciated. Thanks. Link to comment Share on other sites More sharing options...
zukiru Posted December 16, 2011 Share Posted December 16, 2011 You broke a timing belt, most likely. Link to comment Share on other sites More sharing options...
subarurx yo Posted December 16, 2011 Share Posted December 16, 2011 ya could be the timing belt, does it sound different then normal while cranking over? once my cam pulley actually came off the right, due to not torquing down and it kept running on two cylinders but thats why i leave my timing shrouds off is for easier fixin lol i would also check for spark Link to comment Share on other sites More sharing options...
subarurx yo Posted December 16, 2011 Share Posted December 16, 2011 never mind the check for spark i said since you cant if the rotor isnt moving lol Link to comment Share on other sites More sharing options...
evilspawn666 Posted December 16, 2011 Author Share Posted December 16, 2011 Thanks guys. Both belts still there. Someone else said I might have broken shaft on distributor. Thoughts anyone? Link to comment Share on other sites More sharing options...
zukiru Posted December 16, 2011 Share Posted December 16, 2011 (edited) Possible. It's driven by a gear on the cam. Is your rotor the set screw type? They can lose the screw but that would still spin some of the time. You'll just have to pull the dist. and check the shaft and gear. Edited December 16, 2011 by zukiru Link to comment Share on other sites More sharing options...
Ricearu Posted December 16, 2011 Share Posted December 16, 2011 +1 on the rotor screw. even if the timing belts are there, have a friend crank it while you check to see if the driver's side belt is turning the cam. My GL stripped teeth off the belt on the freeway, but didn't snap the belt. so it looked normal, just didn't have any teeth around the crank sprocket to turn Link to comment Share on other sites More sharing options...
1982gl4 Posted December 16, 2011 Share Posted December 16, 2011 +1 on stripping teeth off the belt, my old volvo do that, the belt was perfectly tight, and looked good, but had no teeth to turn it. Link to comment Share on other sites More sharing options...
MilesFox Posted December 16, 2011 Share Posted December 16, 2011 I'll guess that your car has about 135,000-145,000 miles and the factory belts finally went. search 'ea82 timing belt procedure' and 'subaru maintenance' for repair info. Link to comment Share on other sites More sharing options...
evilspawn666 Posted December 16, 2011 Author Share Posted December 16, 2011 Thanks for all the ideas. I will check the teeth on the belt. The rotor does have a set screw but would'nt I have found it in the dist. cap if it came out? This car has 180,000+miles so if it was the original timing belt it held up pretty good eh? Link to comment Share on other sites More sharing options...
zukiru Posted December 16, 2011 Share Posted December 16, 2011 I have the push on types with no screw, but i assume the screw can be loose without it falling off the rotor. Link to comment Share on other sites More sharing options...
