Hi ALL!
This IAC thing is getting beyond stupid ! I've done the clean throttle body with cleaner, still stalls under heavy breaking ! I've replaced the brake booster, also stalls under heavy breaking. I bought the gasket that is link suggested to clean my IAC, it doesn't look anything like what I have ! So..just HOW stupid am I ! I have a '01 Legacy GT Wg, Auto, it's a EJ251 SOHC motor. I thought I could use the procedure in the link below to clean my IAC, before I bought one. MY IAC doesn't look like this ! I've posted a pic of my Subee, just were IS the IAC ? IS it the round thing to the right ? The part number on that sticker is A33-661-R02, I've been told by Subee parts that it's a bad number! What gives !
HELP SubeeTed !
http://forums.nasioc.com/forums/showthread.php?t=781242
Edited by SubeeTed
That's the older style IAC. On the newer cars it's that small round part with the blue sticker on it.
http://subarupartsforyou.com/cp_partdetail.php?partid=3482
That number on the sticker is the part manufacturers part number, not Subarus.
I has a small O ring on the housing that shouldn't need to be replaced. Remove the 2 screws and the valve will pull out of the throttle body. Spray down the valve and the ports in the throttle body with throttle body/ air intake cleaner.
Edited by Fairtax4me
Which is why I "undid" my answer but couldn't figure out how to delete it.
My response was the same about under #3 basically with the 1" stiff hose going to it.
