MexiLoyale Posted December 22, 2011 Share Posted December 22, 2011 I just completed a 6,000 mile trip from Portland, OR to the very southern border of Mexico (Whoo hoo!) in my 92 Loyale. We were loaded to the guts and went really slow up hills but the old girl did great. Just recently she has started to develop some sort of fuel delivery problem. Here's the symptoms: The car sometimes cut power and studders, mostly on acceleration from a stand still or on steep hills. Also when trying to climb steep hills at low speeds it will start to hesitate and then sometimes die all together. When it dies it doesn't want to start again unless I wait a minute or so and then when it does start I have to pump the gas continuously before the rpms will get above 1000. It seems a little better when not loaded down with stuff or once I'm on the highway cruising along. I have replaced the fuel filter and fuel pump after a mechanic here assured me it was the fuel pump. It seemed better for a day or so but then once we were loaded up again and on the road, it was just as bad as always. I also thought about the MAF and tried unplugging it, but then the car wouldn't accelerate hardly at all. I don't really know what that tells me. Any help would be greatly appreciated as no one down here has ever even seen a subaru. THANKS!! Link to comment Share on other sites More sharing options...
MilesFox Posted December 22, 2011 Share Posted December 22, 2011 maybe the coolant temp sensor is bugging out. this explains the hard to start until it sits. It could be ignition related with the transistor on the coil overheating, with the same symptom. try unplugging the engine temp sensor (2 wires green plug, on thermostat housing) and see if the car behaves differently. The transistor is more of a consistent symptom as reported, so i would weigh on it more then the coolant sensor, which seems to act up on mainly mpfi turbo. Link to comment Share on other sites More sharing options...
MexiLoyale Posted December 26, 2011 Author Share Posted December 26, 2011 Thanks Fox, Ill give it a try. The only thing is my problem is really inconsistent and happens when warm or cold. Its worth a shot though! Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2011 Share Posted December 26, 2011 The trouble seems to be with the fuel system from what you stated. If you haven't checked the fuel pressure I suggest you do that. There may be an issue with the pressure regulator or the fuel line is clogged. Link to comment Share on other sites More sharing options...
MexiLoyale Posted January 3, 2012 Author Share Posted January 3, 2012 Thanks Cougar, will do. What is the psi I am looking for? Link to comment Share on other sites More sharing options...
Cougar Posted January 3, 2012 Share Posted January 3, 2012 If you have MPFI, pressures may be around 60psi before the regulator and perhaps 35psi after it. Link to comment Share on other sites More sharing options...
MexiLoyale Posted January 4, 2012 Author Share Posted January 4, 2012 I'm pretty sure its SPFI, but could be mistaken. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted January 4, 2012 Share Posted January 4, 2012 (edited) . Edited January 8, 2012 by Suba_GL_87 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 5, 2012 Share Posted January 5, 2012 That is a Nice Trip. I'll Like to see Pics of your Subie in Mexico. ...no one down here has ever even seen a subaru... That's because they Preffer to buy the "Made in Mexico" Stuff, always, also because that stuff is Tax free there (I mean their Made in Mexico cars doesn't pay import taxes). But there is a Subaru Dealer in Mexico: http://www.subaru.com.mx/ They started to Sell subarus in Mexico in year 2004 But Subarus are considered somehow as High Performance Luxury Cars there, so I only saw two in mexico when I went there in 2005: one in their Capital City (D.F. Federated District) and another in Acapulco City; both imprezas. The rest of latin america has more Subarus than Mexico. Kind Regards. Link to comment Share on other sites More sharing options...
MexiLoyale Posted January 5, 2012 Author Share Posted January 5, 2012 (edited) maybe the coolant temp sensor is bugging out. this explains the hard to start until it sits. It could be ignition related with the transistor on the coil overheating, with the same symptom. try unplugging the engine temp sensor (2 wires green plug, on thermostat housing) and see if the car behaves differently. Tried it, but it was much harder to start, then had a lot of problems accelerating. What does that tell me? Also, just realized I'm getting a code 34, although no check engine light... EGR valve or solenoid,,, could that explain my symptoms? Edited January 5, 2012 by MexiLoyale Link to comment Share on other sites More sharing options...
Cougar Posted January 7, 2012 Share Posted January 7, 2012 Code 34 is for the EGR valve or circuit. The circuit may be open so check that. It may be a good idea to clean the EGR valve also along with the MAF sensor. Check the fuel pressure. The regulated pressure should be 35psi. Link to comment Share on other sites More sharing options...
MexiLoyale Posted January 8, 2012 Author Share Posted January 8, 2012 I'll Like to see Pics of your Subie in Mexico. Id love to post one but am new to this message board and cant figure out how.... its been a great trip though! Link to comment Share on other sites More sharing options...
MexiLoyale Posted January 8, 2012 Author Share Posted January 8, 2012 Code 34 is for the EGR valve or circuit. The circuit may be open so check that. It may be a good idea to clean the EGR valve also along with the MAF sensor. Check the fuel pressure. The regulated pressure should be 35psi. Cleaned the MAF, the EGR valve is next. Do I just scrape out the ports or can I clean the actual valve itself? Any recommendations on how to do that? Also Cougar, 35 psi is correct for SPFI? Thanks a ton for your help! Link to comment Share on other sites More sharing options...
Cougar Posted January 8, 2012 Share Posted January 8, 2012 To post a picture click on the icon that shows a mountain scene in the area above the reply box and enter a URL address to the picture. To clean the EGR valve you may need to scrape out the hard crude and follow up with some cleaner. Link to comment Share on other sites More sharing options...
MexiLoyale Posted January 9, 2012 Author Share Posted January 9, 2012 Cleaned the EGR and now she starts with ease and I didn't notice any problems with the hesitation on acceleration... Hopefully that solves it!!! Thanks a ton! Link to comment Share on other sites More sharing options...
Cougar Posted January 10, 2012 Share Posted January 10, 2012 It sounds like you found the trouble. Thanks for the update and you're welcome for the help. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 10, 2012 Share Posted January 10, 2012 I'm Glad to know that you Fixed your Subie! Id love to post one but am new to this message board and cant figure out how.... its been a great trip though! To Post pictures here, you just need to Upload them to a free pictures hosting website, such like Flikr, Imageshack or Photobucket. Then you need to Copy the Image's URL code from that site, and then... ... click on the icon that shows a mountain scene in the area above the reply box and enter a URL address to the picture... Photobucket also provides an IMG code that you simply copy from there and Paste here, and Voilá. Kind Regards. Link to comment Share on other sites More sharing options...
