91 subaru Posted December 24, 2011 Share Posted December 24, 2011 Alright i have a 91 loyale wagon 4x with 235-75-15's. I was thinking about rebuilding the 1.8. I was wonderin what some opinions would be on rebuilding the 1.8 or should i look for an ej to swap in. also if i did the ej swap i see alot of people going to a manual trans. Mine is the 3 speed auto and id kinda like to keep it. Anyway opinions, rebuild vs. Swap? Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 24, 2011 Share Posted December 24, 2011 Do you want the same power or more power?? Same power = rebuild your 1.8 more power = swap in a 2.2 Ditch the 3AT no matter which choice you pick. Link to comment Share on other sites More sharing options...
91 subaru Posted December 25, 2011 Author Share Posted December 25, 2011 I knew keeping the 3at was gonna be a bad idea. Id hate to get rid of it cause its only got about 20000 on a rebuild. id love more power tho. i remember someone somewhere said the 3at couldnt handle more power. so if i did the swap keeping it wouldnt be a good idea. So what would be the suggestions on the ej and trans? Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 25, 2011 Share Posted December 25, 2011 It might be able to handle the power, however you would never know cause you wouldnt feel any difference. The 3AT sucks up all the horsepower, its seriously a horrible transmission. Link to comment Share on other sites More sharing options...
Subruise Posted December 25, 2011 Share Posted December 25, 2011 if you need an auto go ej and 4eat. no adaptor plate needed. good time to 5 lug that thing too, or use fwd ej axles. the 4eat is a good trans. Link to comment Share on other sites More sharing options...
91 subaru Posted December 25, 2011 Author Share Posted December 25, 2011 I dont have to have an auto. Just prefer it. If i do an ej with a 4eat do i need a shorter drrive shaft. I also have sixlugs Link to comment Share on other sites More sharing options...
cal_look_zero Posted December 25, 2011 Share Posted December 25, 2011 I'd drop in an EJ22 with a 5mt d/r behind it. Link to comment Share on other sites More sharing options...
91 subaru Posted December 25, 2011 Author Share Posted December 25, 2011 Ok im gonna go do some research on this manual trans. Link to comment Share on other sites More sharing options...
MilesFox Posted December 25, 2011 Share Posted December 25, 2011 find a gl-10 with a 4eat, and swap an ej4eat with ej motor. Link to comment Share on other sites More sharing options...
91 subaru Posted December 25, 2011 Author Share Posted December 25, 2011 Ok i just read numbchux write up on the ea to ej swap. The way i read it, it sounds like im gonna have some parts off a couple different cars. If i use ej motor and trans will i have to use different spindles. Since the ea is splined differently. Also cross members. Can i just use the cross memebers off the ej car? Link to comment Share on other sites More sharing options...
91 subaru Posted December 27, 2011 Author Share Posted December 27, 2011 Ok so ive been reading a bunch of poat the last couple days. Seems like two cars are needed for and ej swap. Sounds like everythink i read leads to a mt trans swap as well. Im starting to think im gonna be better off just rebuilding the 1.8. Link to comment Share on other sites More sharing options...
Cyfun Posted December 27, 2011 Share Posted December 27, 2011 Believe me, with those tires you're running, you'll love having both an EJ22 and a dual range trans. I just finished mounting my 235/75r15's this weekend, and am very glad that I don't have the stock motor. At 80mph in 5th gear I'm only doing 3000rpm. Link to comment Share on other sites More sharing options...
zukiru Posted December 27, 2011 Share Posted December 27, 2011 is the 1.8 dead? I mean if it ain't broke... Link to comment Share on other sites More sharing options...
91 subaru Posted December 27, 2011 Author Share Posted December 27, 2011 zukiru said: is the 1.8 dead?I mean if it ain't broke... I think the head is taking a crap on me. Either that or the intake gasket. I put new intake gaskets on about 3 months ago and i noticed yesterday that there was some antifreeze around the intake. I snugged those bolts down. I pulled the hose off the driverside head and noticed it was full of what looked like oily milk. Im pretty sure that stuff came from water being in the head. Link to comment Share on other sites More sharing options...
91 subaru Posted December 27, 2011 Author Share Posted December 27, 2011 Cyfun said: Believe me, with those tires you're running, you'll love having both an EJ22 and a dual range trans. I just finished mounting my 235/75r15's this weekend, and am very glad that I don't have the stock motor. At 80mph in 5th gear I'm only doing 3000rpm. As far as swappin in the ej. How hard is it to put in the mt? Also am i correct on needing an xt and a legacy? Link to comment Share on other sites More sharing options...
Cyfun Posted December 28, 2011 Share Posted December 28, 2011 Are you referring to the EA82 dual range 5 speed, or the EJ AWD 5 speed? The EJ trans will swap straight across, but I think you'll need the driveshaft shortened. The EA trans will just need an adaptor plate, and probably a new clutch while you're at it. Link to comment Share on other sites More sharing options...
zukiru Posted December 28, 2011 Share Posted December 28, 2011 (edited) don't you need a different tranny mount (xt6) to run an EJ trans in a GL? Edit: automatics... Duh... Ignore this post. Edited December 28, 2011 by zukiru Link to comment Share on other sites More sharing options...
91 subaru Posted December 29, 2011 Author Share Posted December 29, 2011 So the ej motor with an ea trans sounds easiest. Question is how hard is it to put in the clutch peda and the different console? Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 29, 2011 Share Posted December 29, 2011 Ok since you are now talking about swapping in a manual transmission, do that swap first, get it buttoned up and then swap in the EJ. You will need a few things for the manual swap but it's very easy to do. You will need... Manual transmission Clutch kit, flywheel and the flywheel bolts, not the ones for the flex plate (AT cars) as they are shorter then the flywheel bolts Pedal cluster. Easy to remove and install if the steering column is removed as well Driveline as it is longer then the 4eat but is still longer then the 3at I believe Shifters, boot and interior trim if you care Crossmember Clutch cable Speedometer cable as it is different then the autos Gauge cluster, again if you care Only thing you will need to do electrically is put a jumper wire in the 6 pin plug (might be 8) that plugs into the stock auto shifter assembly on the two largest wires that go into it. These are for the neutral safety switch which is located in the shifter assembly. You can also run these two wires to a hidden switch for a "kill" switch if desired. Link to comment Share on other sites More sharing options...
Gloyale Posted December 29, 2011 Share Posted December 29, 2011 Do the EJ swap first. The trans will hold up[ fine for a while. If you go with an EJ18, you'll have better power and torque than your current engine. Cheaper, less likely to break the 3at, and easily upgradeable later to 2.2 look for an old beat up body impreza. Link to comment Share on other sites More sharing options...
91 subaru Posted December 29, 2011 Author Share Posted December 29, 2011 Gloyale said: Do the EJ swap first. The trans will hold up[ fine for a while. If you go with an EJ18, you'll have better power and torque than your current engine. Cheaper, less likely to break the 3at, and easily upgradeable later to 2.2 look for an old beat up body impreza. Thats what im looking for. Power and torque. Which is better of an engine? Ej18 or ej22? I know the ej22 is gonna be "bigger" but which is more durable. Ive put a heck of a beating on the ea82! Link to comment Share on other sites More sharing options...
Cyfun Posted December 29, 2011 Share Posted December 29, 2011 If you can find an EJ22 for a good deal, might as well go with that. The engines are basically the same except for the EJ18 has about 110hp and the EJ22 has about 135hp. Link to comment Share on other sites More sharing options...
91 subaru Posted December 29, 2011 Author Share Posted December 29, 2011 135 sounds pretty good cimpared to my 90! I have a few picked out. Even found a cheap dohc 2.5 from a 96 legacy, but i need to do a little more research on that swap. Thanks for all the great info and suggestions tho. Link to comment Share on other sites More sharing options...
Cyfun Posted December 29, 2011 Share Posted December 29, 2011 Probably wanna stay away from a 2.5 due to the reliability issues. And bear in mind that having an entire parts car might be a good idea, especially if you're swapping to a manual. Link to comment Share on other sites More sharing options...
91 subaru Posted December 30, 2011 Author Share Posted December 30, 2011 Caboobaroo said: Manual transmission Clutch kit, flywheel and the flywheel bolts, not the ones for the flex plate (AT cars) as they are shorter then the flywheel bolts Pedal cluster. Easy to remove and install if the steering column is removed as well Driveline as it is longer then the 4eat but is still longer then the 3at I believe Shifters, boot and interior trim if you care Crossmember Clutch cable Speedometer cable as it is different then the autos Gauge cluster, again if you care. Ok im gonna start workin on this list of parts. Anyone think of anything else? Oh and if someone happens to be selling any of these items feel free to pm me Link to comment Share on other sites More sharing options...
