coolant leak after coolant change
great info from the outback forum, even if it isn't for your year, the basics apply.
Colin,
I am the tech manager at Prestone Antifreeze. Check out these service bulletins on your car regarding coolant loss
NUMBER: 08-52-08
DATE: 08/18/08
APPLICABILITY:
1999MY and later Impreza & Forester
2000MY and later Legacy & Outback
2006MY and later Tribeca
SUBJECT: Coolant Overflow
Introduction
If you encounter a vehicle which experiences coolant coming out of the coolant reservoir tank, it may be caused by the radiator cap pressure valve being stuck open by debris sucked up through the reservoir tank hose. As the cooling system cools down, it sucks coolant back into the radiator. If there is debris that settles to the bottom of the reservoir tank, the hose is low enough to also suck them back into radiator. This causes the radiator cap not to seal, allowing excessive amount of coolant to escape overflowing the reservoir tank. If this condition continues over time, there will not be enough coolant in the system to maintain proper engine temperature.
In order to correct the condition you need to clean (and test) or replace the radiator cap, clean out the reservoir tank, and shorten the hose slightly, following the repair procedure.
Production Line Change
139876308
The shorter coolant reservoir tank hose was used in production as shown above.
Repair Procedure/Information
1.Radiator Cap Cleaning
Many caps can be successfully cleaned. The important part is the thorough cleaning of the negative pressure valve. If this is not done completely, remaining debris may result in a repeat issue. If there is an excessive amount of debris or the sealing rubber on the cap appears to be pitted or damaged, replace the cap.
Note: If replacing the cap, skip to Step 2.
139876310
Using clean water and a brush, thoroughly clean the cap seal surface.
Note: A used toothbrush which has been cleaned works great.
139876313
Manually open the negative pressure valve. Using clean water and a brush, thoroughly clean the valve (inner and outer surface) and the valve seal surface.
Check the radiator cap valve opening pressure using a radiator cap tester to insure the cap is within specification (refer to the applicable Subaru Service Manual).
Note: If the cap is out of specification replace it.
2.Coolant Reservoir Tank Cleaning
139876561
Remove the reservoir tank (refer to the applicable Subaru Service Manual).
Using clean water, thoroughly clean the inside of the reservoir tank.
Reinstall reservoir tank. Fill with coolant to the Full mark.
Note: Be sure to use genuine Subaru Super Coolant or Subaru Long Life Coolant, depending upon what type of coolant is currently in the system.
3.Coolant Reservoir Tank Hose Modification
139876563
Remove the hose from the reservoir tank. Cut 20 mm from the bottom of the hose at a 45°angle. Reinstall hose in reservoir tank.
Start engine and permit to fully warm up.
Turn off engine and allow to fully cool down.
Recheck coolant level in reservoir and add coolant if needed.
139876315
Warranty/Claim Information
blnk_spc.gif© 2011 ALLDATA LLC. All rights reserved.Terms of Use
Edited by johnceggleston
too long for one post, here's the rest of it.
NUMBER: 09-42-05
DATE: 04/15/05
APPLICABILITY:
All Models
SUBJECT:
Cautions Concerning Engine Coolant
INTRODUCTION
The purpose of this bulletin is to inform of cautions concerning engine coolant.
REPAIR PROCEDURES/INFORMATION
When adding, replacing or servicing the cooling system always use Genuine Subaru Long Life Coolant. Genuine Subaru Long Life Coolant is a phosphate (non-amine) type and is specially formated for all Subaru vehicles equipped with aluminum engines and radiators. Coolant of other types may not provide the proper protection to aid against corrosion of aluminum parts. If an equivalent must be used, make sure it is a phosphate (non-amine) type. As a reminder, use of Genuine Subaru Long Life Coolant is mandatory on all repairs paid for by Subaru of America, Inc, that require the replenishment of coolant. This holds true for any claim type.
Do not use flushing machines.
If a flushing machine has been used to service other brand vehicles with copper radiators, a chemical reaction between copper ions and Subaru coolant may occur. This could also cause clogging of the radiator.
If regular flushing is required, only use fresh tap water. Do not use hard water. Hard water will create calcium build-up which will clog the radiator.
Whenever the coolant is changed, you must add Genuine Subaru Cooling System Conditioner. Genuine Subaru Cooling System Conditioner has been tested and approved for aluminum engines and radiators.
Do not use after-market coolant reinforcement agents, sealers and/or flushing agents as those chemicals could corrode aluminum parts.
84949687
Disclaimer
And last, the cylinder head issue-
NUMBER: WWP-99
DATE: 02/2004
APPLICABILITY:
2000-2002MY Subaru Legacy and Outback;
1999-2002MY Impreza; 1999-2002MY Forester
SUBJECT:
Engine Cooling System Conditioner
INTRODUCTION
Subaru of America, Inc. (SOA) has determined that over time, affected vehicles may develop small external coolant leaks at engine cylinder head gaskets. This is the result of normal expansion and contraction of engine components caused by the heating and cooling of these parts. To prevent cylinder head gasket leaks from developing or to correct existing leaks, a special Subaru Cooling System Conditioner should be added to affected vehicle cooling systems.
This Service Program will involve adding one bottle of Genuine Subaru Cooling System Conditioner to the engine cooling system.
AFFECTED VEHICLES
2000-2002 MY Subaru Legacy and Outback with 2.5L engine.
1999-2002 MY Impreza with 2.5L engine.
1999-2002 MY Forester with 2.5L engine.
Affected vehicles are identified in the VIN range chart below. Only vehicles with a 2.5L engine are affected.
NOTE :Prior to performing repairs, confirm coverage for potentially affected vehicles by using the Vehicle Coverage Inquiry in the Dealer Communication System (DCS).
105869295
Vehicles identified in the preceding chart may include VINs that were not distributed in the U.S. market. Dealers will be provided a list of VINs that include the owner name and address. This information will enable dealers follow-up with owners of potentially affected vehicles. These listings contain owners names and addresses obtained from State Motor Vehicle Registration Records. The use of such motor vehicle registration data for any other purpose is unlawful. Accordingly dealers are urged to limit the use of this listing only for the purpose of completion of this service program.
OWNER NOTIFICATION
SOA prepare and mail an Owner Notification Letter to owners of the affected vehicles. Because of the number of vehicles affected and parts availability, owner notification will occur on or about the dates listed in the following four stages.
1999 MY - February 16, 2004
2000 MY - March 1, 2004
2001 MY - April 1, 2004
2002 MY - May 3, 2004
A copy of the owner notification letter is included at the end of this bulletin.
OWNER REIMBURSEMENT FOR PREVIOUS REPAIRS
Owners are being advised in the owner notification letter, found at the end of this bulletin, that if they have previously paid an authorized Subaru dealer for repairs related to this Service Program, they may be entitled to reimbursement. The owners are further advised, to qualify for any reimbursement they must submit the original repair invoice to Subaru of America, Inc. Please review the owner notification letter, which explains this procedure so that you are familiar with it, and can assist owners with any questions.
FUTURE MAINTENANCE
In the future, it will be necessary to add Genuine Subaru Coding System Conditioner to the coding system of affected vehicles whenever the engine coolant is replaced. As a reminder, owners will be sent update pages with their notification letter that instructs them to add the pages to their Owner's Manual and Warranty and Maintenance Booklet Except for the initial application associated with this campaign, the cost of adding the conditioner is the owner's responsibility.
CYLINDER HEAD GASKET WARRANTY EXTENSION
For owners of affected vehicles that have this Service Program performed promptly, SOA is extending coverage under the Subaru Limited Warranty for cylinder head gasket external coolant leaks to a period of 8 years or 100,000 miles, whichever occurs first Warranty coverage begins on the date the vehicle was delivered to the first retail purchaser. If the vehicle was used as a demonstrator or company vehicle before being sold at retail, warranty coverage begins on the date the vehicle was first placed in such service.
As a further condition for this extended warranty coverage to apply, the owner must properly maintain the vehicle's cooling system in accordance with the recommended maintenance schedule and Genuine Subaru Cooling System Conditioner must be added each time the engine coolant is replaced. Resulting damage caused by a lack of maintenance or low coolant level will not be covered. Replacement of the Cooling System Conditioner during inspection and maintenance services is not covered under warranty.
DEALER PROGRAM RESPONSIBILITY
Dealers are to promptly service vehicles subject to this Service Program at no charge to the vehicle owner regardless of mileage, age of the vehicle, or ownership.
For affected vehicles sold after the date on the dealer's computer list, dealers are to contact those owners and provide them with a copy of the owner notification letter. They should also arrange to make the required correction according to the instructions in the service procedure section of this bulletin.
105869296
Vehicles in Dealer Inventory
Dealers are also to promptly perform the applicable service procedures defined in this bulletin to correct affected vehicles in their inventory (new, used, demo). Additionally, whenever a vehicle subject to this Service Program is taken into dealer new or used inventory, or is in the dealership for service, necessary steps should be taken to ensure the Service Program correction has been made before selling or releasing the vehicle.
New or used vehicles listed in a recall/campaign that are in dealer stock must be:
^Immediately identified.
^Tagged or otherwise marked to prevent their delivery or use prior to inspection and/or repair.
^Inspected and/or repaired in accordance with instructions outlined in the Product Campaign Bulletin.
Any Authorized Subaru Dealer failing to perform the applicable service procedures defined in this bulletin to correct affected vehicles in their inventory (new, used, demo) prior to the vehicle being placed in service may be in breach of the Subaru Dealer Agreement.
PARTS INFORMATION
Note :Subaru Cooling System Conditioner is packaged in cases that contain 12 bottles. Each affected vehicle requires one (1) bottle. Each case contains enough material to treat 12 vehicles.
Prior to the release of this Service Program, each dealer will automatically be shipped a quantity of Subaru Cooling System Conditioner equivalent to 40% of their vehicle sales, or up to a maximum of 20 cases.
Additional quantities of the Cooling System Conditioner will be available through normal parts channels after 2/15/04. In order to maintain an adequate part supply, SOA requests that Dealers only order quantities necessary to satisfy anticipated demand.
REPAIR PROCEDURES
The repair procedure involves adding Subaru Cooling System Conditioner to the cooling system. Follow the recommended procedure that applies to either a "Cold" or "Hot" engine.
Caution :The engine cooling system is under pressure and may he extremely hot. To prevent personal injury or vehicle damage he sure to take appropriate precautions while performing this procedure.
Service Procedure on a COLD Engine
NOTE :Impreza and Forester vehicle system components are shown in the images below, but Legacy and Outback models are similar. Consult your service manual for exact locations and illustrations.
105869297
1.Install rags around the radiator filler neck to prevent coolant from contaminating the engine area.
105869298
2.Take off the radiator cap and set aside.
105869299
3.Extract 125ml (4.23 oz.) of coolant from the radiator using a suitable device such as a piston syringe, meat or poultry baster, antifreeze hydrometer, etc.
105869300
4.Place the syringe into the overflow reservoir and push the coolant out of the syringe.
5.Shake the bottle of cooling system conditioner until all contents are thoroughly mixed.
6.Pour the entire bottle of cooling system conditioner into the radiator.
NOTE biggrin.gifo NOT pour the cooling system conditioner into the overflow reservoir. The conditioner Will settle at the bottom of the reservoir and not mix in the cooling system.
7.Reinstall the original radiator cap.
8.Remove rags from around the radiator filler neck.
9.Start the vehicle and let it run until the engine is warm. This ensures the conditioner circulates and there are no air pockets in the cooling system.
Service Procedure on a HOT Engine
1.Turn the ignition key to the "ON" position (engine off).
2.Turn the air conditioning "ON" to cycle the cooling fans. Leave the air conditioning "ON" for approximately two (2) minutes. This will lower the pressure in the cooling system.
NOTE :The pressure relief on a "HOT" engine is approximate. Caution should always be taken when removing the radiator cap on a "HOT" engine. Additional A/C "ON" time may be required to relieve cooling system pressure properly.
3.Turn off the air conditioning.
4.Return the ignition key to the LOCK ("OFF") position.
5.Follow procedure for COLD engine listed above.
RECALL CAMPAIGN IDENTIFICATION LABEL
105869301
Type or print the necessary information on a Recall Campaign identification label. The completed label should be attached to the vehicle's upper radiator support.
CLAIM REIMBURSEMENT AND ENTRY PROCEDURES
Credit for performing this Service Campaign will be based on the submission of properly completed repair order information. Dealers may enter the applicable claim information through their Dealer Communications System.
Listed below is claim entry information:
Add Engine Cooling System Conditioner - Use the following information for claim submission:
105869302
Enter labor operation 122-801 for 0.2 labor hours.
105869303
Enter the applicable part number. Parts will be reimbursed at dealer cost plus applicable handling allowance.
84949687
Disclaimer
Hope this info helps, you can email me with any cooling system questions at jay.buckley@framgrp.com
got some sealant , still leaks but only leaks after driving it and sitting with motor off size of a quarter , so trying to see where it leaks , checked all hoses after sitting all nite, all look good , but will drive it again and check again , any suggestions
started to leak between motor and tranny quarter size
which side of the engine?
are you sure it is antifreeze?
the only coolant that far back are the heater hoses or thew driver side head gasket, rear corner.
lots of things leak in the area of the rear of the engine, but not all are coolant.
