1996 OB wagon, 2.5L what type lash adj?
HLA (hydraulic lash adjuster) 1996 OB Wagon Auto-2.5L - (made 07-95) with Sq plug wires, kinda sure that’s what type I got. any other way to identify lash adj? other than valve cover R&R? Just bought the car last week and am getting ready to chase a PO304( cyl 4 misfire) with NGK plugs (going with Iridium) and still looking for wires- been reading the threads- either OEM or NGK, nobody stocks them
the only way to tell, short of looking inside, is to call the dealer with the vin.
mis-fires are usually wire or plug related. NGK plugs and subaru wires. you can try moving the #4 wire to another cylinder to see if the misfire moves with the wire.
if that does not do it check the compression on #4. burned exhaust vavles are not unheard of, but it is usually wires.
