ShawnW Posted April 21, 2012 Share Posted April 21, 2012 1 Lucky Texan said: $10.48 w/seal at Rockauto My best price is with the seal too. Just seeing it as a Tama like GD indicated-not a Stant branded one yet. Im digging though. RockAuto is tough but not impossible to beat. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 21, 2012 Share Posted April 21, 2012 ShawnW said: My best price is with the seal too. Just seeing it as a Tama like GD indicated-not a Stant branded one yet. Im digging though. RockAuto is tough but not impossible to beat. gotcha - and sometimes Amazon beats RockAuto with free shipping. Link to comment Share on other sites More sharing options...
1997reduxe Posted April 24, 2012 Share Posted April 24, 2012 Don't kno if anyone noticed this, but when I searched Rockauto for this Stant one mentioned above, there is listed also one from Gates (#34012) which at least in the picture is identical, for $9.90. I called them and the woman said there's no correlation between use of same pic and that they are necessarily made by the same manuf, as any product sold may be supplied by various original makers. I don't suppose anybody's ever tried the Gates one? Thnkx Link to comment Share on other sites More sharing options...
sosubeme Posted May 23, 2012 Share Posted May 23, 2012 (edited) Hi all, just received the Stant "xactstat" 48457 from Amazon. Have concerns about using it because..."Made in Germany" is on the box, "78°C" is the only stamping I can find on it (no emblems), and only has two tabs that attach cage to the mounting plate instead of the four on my old one. Anyone else get one like this? Vendor switch? Advice? Hopefully thumbs for illustration show up. Thanks! Edited May 23, 2012 by sosubeme typo Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 23, 2012 Share Posted May 23, 2012 I'll try to take a look at mine later tonight. Link to comment Share on other sites More sharing options...
sosubeme Posted May 23, 2012 Share Posted May 23, 2012 1 Lucky Texan said: I'll try to take a look at mine later tonight. Thanks much! Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 24, 2012 Share Posted May 24, 2012 OK, mine differs from yours in only 2 ways that I can tell, the box says made in japan (in 3 languages like yours) and the 78*C marking is on the other side of the 'tickler'. mine even has that offset dimple in the brass on the bottom of the 'wax filled slug' or w'ever. same construction and shape. Link to comment Share on other sites More sharing options...
sosubeme Posted May 24, 2012 Share Posted May 24, 2012 1 Lucky Texan said: OK, mine differs from yours in only 2 ways that I can tell, the box says made in japan (in 3 languages like yours) and the 78*C marking is on the other side of the 'tickler'. mine even has that offset dimple in the brass on the bottom of the 'wax filled slug' or w'ever. same construction and shape. Thanks for the follow up 1 Lucky Texan, much appreciated! There is a dealership nearby. May wander over and have a look at one of theirs, before deciding if I should stick this one in. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 24, 2012 Share Posted May 24, 2012 sosubeme said: Thanks for the follow up 1 Lucky Texan, much appreciated! There is a dealership nearby. May wander over and have a look at one of theirs, before deciding if I should stick this one in. no problem, it was right there in my home 'office'. I bought it over a year ago from RockAuto. Haven't decided to use it yet, but it was gonna be a maintenance replacement anyway - both cars are working well at present. Link to comment Share on other sites More sharing options...
sosubeme Posted May 24, 2012 Share Posted May 24, 2012 1 Lucky Texan said: no problem, it was right there in my home 'office'. I bought it over a year ago from RockAuto. Haven't decided to use it yet, but it was gonna be a maintenance replacement anyway - both cars are working well at present. Maybe not the same Stant vendor? In the middle of a t-belt, pulleys, cam and crank seals, WP, oil pump and cam O-rings job myself, hoping to finish up soon. Then maybe it'll hold fluids! Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 24, 2012 Share Posted May 24, 2012 sosubeme said: Maybe not the same Stant vendor? In the middle of a t-belt, pulleys, cam and crank seals, WP, oil pump and cam O-rings job myself, hoping to finish up soon. Then maybe it'll hold fluids! wow - yeah, hope all that work is fruitful. Link to comment Share on other sites More sharing options...
1997reduxe Posted May 25, 2012 Share Posted May 25, 2012 I will just throw in about how when I got the Stant one that I just used in my t-belt kit job, that seems to be working fine, I decided not to use their rubber gasket, as the one that came with my Aisin water pump seemed much thicker and better constructed. 2 more cents... Link to comment Share on other sites More sharing options...
sosubeme Posted May 25, 2012 Share Posted May 25, 2012 (edited) 1997reduxe said: I will just throw in about how when I got the Stant one that I just used in my t-belt kit job, that seems to be working fine, I decided not to use their rubber gasket, as the one that came with my Aisin water pump seemed much thicker and better constructed.2 more cents... Thanks for your input 1997reduxe! Stopped by the dealership and had a look at the Subaru part. They matched an online dealer price, so I picked it up there along with the gasket. Compared to the Stant product, there are cosmetic differences, which may not have an impact upon functionality / performance. Peace of mind and all else considered, I believe the Subaru thermostat is worth the $8.00 above what I paid for the Stant product, and will be using same when installing the new pump. Cheers! Edited May 25, 2012 by sosubeme typo.....again! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 27, 2012 Author Share Posted May 27, 2012 I'm sure the German one would have been fine. I've seen a few variants of the "OEM" EJ thermostat and as long as they have the same opening diameter, the machined jiggle pin, and the large diamter spring that we are all used to they have worked without issue. I've installed tons of thermostat's and this has been the case 100% of the time. I've seen at least three variants of the OEM design and all have been fine. The one's that are a problem have a smaller diameter opening, a weak/small looking spring, and often no jiggle pin. These are the "domestic" equivelents and they aren't designed with cold-side control in mind. They are desiged for hot-side control systems as used on almost all domestic cars and trucks. GD Link to comment Share on other sites More sharing options...
sosubeme Posted May 27, 2012 Share Posted May 27, 2012 Thanks for the info GD, good to know!Thought I'd bring it up as hadn't come across mention of it elsewhere.Now I have a go-to spare for either vehicle. I saw your post elsewhere concerning crank seal install issues, will pose questions there, hope you'll comment. Link to comment Share on other sites More sharing options...
vasy Posted May 27, 2012 Share Posted May 27, 2012 sosubeme said: Hi all, just received the Stant "xactstat" 48457 from Amazon. Have concerns about using it because..."Made in Germany" is on the box, "78°C" is the only stamping I can find on it (no emblems), and only has two tabs that attach cage to the mounting plate instead of the four on my old one. Anyone else get one like this? Vendor switch? Advice? Hopefully thumbs for illustration show up. Thanks! I got one from Amazon.com about 2 months ago and it's also made in Germany, just like the one you got. The only difference is that the temp carved on the t'stat is 170 F, not 78 C. I put a 2-year-old OEM unit and this new German one in hot water on the stove. This new one opened a tad sooner than the OEM which makes sense - 170 F is a tad lower than 78 F. I installed this German one on my 96 2.5 and have had no problems. Link to comment Share on other sites More sharing options...
sosubeme Posted May 27, 2012 Share Posted May 27, 2012 vasy said: I got one from Amazon.com about 2 months ago and it's also made in Germany, just like the one you got. The only difference is that the temp carved on the t'stat is 170 F, not 78 C. I put a 2-year-old OEM unit and this new German one in hot water on the stove. This new one opened a tad sooner than the OEM which makes sense - 170 F is a tad lower than 78 F. I installed this German one on my 96 2.5 and have had no problems. Thanks for your info, that's good to hear! I'll plan on using it the next time. Link to comment Share on other sites More sharing options...
NWSubie Posted January 19, 2013 Share Posted January 19, 2013 The T-stat on the left is the one Napa gave me when I did my EJ swap in my 80 wagon. The car took forever to heat up and often would not clear all the moisture off the windows. The new Stant one I installed looks a lot different and I actually thought I had ordered the wrong one due to the size difference but nope it installed as it should and works great so far. Car heats up quicker although I have not driven it long enough to see if I can actually defog all of the windows yet. Thanks GD for making this link thats how I heard about this great non-oem option. :cool: Link to comment Share on other sites More sharing options...
Hakim Craddock Posted February 25, 2013 Share Posted February 25, 2013 (edited) i can attest to the fact that the wrong tstat in a subaru will cause ovrheating.. 03 forester that i just purchased, would overheat on the highway on any type of hill small, medium or large! Heat would be erratic (go from very hot to normal to warm to hot etc)... i was convinced that i had a blown head gasket so today i finally got some free time, hunted down one of these thermostats at pepboys, pulled the old one out and sure enough it was the small tstat shown on the left in the picture above (a big smile came to my face, then i realized that it might have been changed because they were trying to solve an overheating problem...sigh), so i swapped it out for the 48457 t stat. drove 20+ miles on the highway up various size hills that just earlier in the day made the forester overheat, NOW my temperature was steady and no signs of overheating... I think/hope its safe to say that my problems have been solved by this t stat. ohh and BTW my headgaskets are leaking but its a minor external oil leak, and i can live with that! The xactstat that i got from pepboys said made in Germany. Edited February 25, 2013 by Hakim Craddock Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 24, 2013 Share Posted June 24, 2013 I ordered a Gates 34012 from rockauto a few days ago, mostly out of curiosity because their picture looked very similar to a Subaru OE stat. It's not quite exactly the same as the pictures I can find of the Subaru part, but its so close I think itll work just fine for the $9 and change I paid for it. It bumped the shipping cost up by only $0.50 since it came from the same warehouse as some other parts I ordered. Looks the same as the Stant version to me. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 25, 2013 Share Posted June 25, 2013 that gates 'looks' OK from the pic. Been running the xacstat in our 03 H6 since April - no difference detected from the original. Link to comment Share on other sites More sharing options...
avk Posted July 19, 2013 Share Posted July 19, 2013 (edited) Just noticed that OE new-gen. thermostats, although physically all the same, come with at least three different temperature setiings. Specifically, 21200AA072: 78C 21210AA030: 84C 21210AA080: 82C Most aftermarket vendors cover all three applications with a single part, a 78C thermostat. PS: this is incorrect, read on. Edited July 19, 2013 by avk Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 19, 2013 Share Posted July 19, 2013 (edited) On 7/19/2013 at 4:27 PM, avk said: Just noticed that OE new-gen. thermostats, although physically all the same, come with at least three different temperature setiings. Specifically, 21200AA072: 78C 21210AA030: 84C 21210AA080: 82C Most aftermarket vendors cover all three applications with a single part, a 78C thermostat. dunno if these links will work, I've had trouble with that before at opposedforces but, here goes; -072 (78*C usage) - http://opposedforces.com/parts/info/21200AA072/ (removed - thanx avk) -030 (84*C) - http://opposedforces.com/parts/info/21210AA030/ -080 (82*C) - http://opposedforces.com/parts/info/21210AA080/ Edited July 19, 2013 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
avk Posted July 19, 2013 Share Posted July 19, 2013 (edited) On 7/19/2013 at 4:44 PM, 1 Lucky Texan said: Is there a breakdown on year/model usage? I only have a general idea. it's best to check the temperature stamped on the factory unit. In a few words, AA072 is the "good old" for EJ22/EJ18/EG33 and earlier EJ25. All 6-cyl. EZ engines use AA080. On newer EJ25, both AA030 and AA080 can be found (source: opposedforces). I'm not quite sure if that was a year-to-year change, or a difference between turbo and non-turbo models. Edited July 19, 2013 by avk Link to comment Share on other sites More sharing options...
avk Posted July 19, 2013 Share Posted July 19, 2013 (edited) Thanks. I tried to find about about the -AA170 version, and it appears to be the -AA080 without the gasket. This can be found only if you choose Euro applications, http://opposedforces.com/parts/legacy/en_b12/type_21/cooling_system/water_pump/ You can also see there that early on, they changed the specification from 84C to 82C for the 6-cyl engine. By the time it became available in the US, it was 82C only. PS that info seems inconsistent because according to it, 21200AA072 is 21210AA030 sans the gasket. I don't think that's correct, need to double-check. The photo which led me to believe -AA030 was a 84C thermostat found here: http://minkara.carview.co.jp/en/userid/429470/car/344057/2093820/parts.aspx Edited July 19, 2013 by avk Link to comment Share on other sites More sharing options...
