Rpm90001 Posted December 27, 2011 Share Posted December 27, 2011 I just installed my drawtite trailer hitch and wiring harness.....well almost.. I ran the power wire that goes to the battery under the carpet and got it to under the dash. The problem is, I can't find an access hole to run the wire to the engine compartment. I just quit because it's late and will finish it in the morning. Anyone know if a good access spot to run the power wire? I believe it is a 12g wire. Figured I would ask here to see if anyone ran into this problem. This is the first car I could not find a access spot. Also, the drawtite hitch hangs a lot lower than I thought... Not to happy with design. Thanks, Geo Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 27, 2011 Share Posted December 27, 2011 The 96 - 99 cars had a good spot right where the fuel lines come into the fire wall behind the drivers strut tower. There are 3 lines, but a plug in the firewall with 4 "nipples". Poke a hole in the empty one and feed the wire through. Link to comment Share on other sites More sharing options...
subie94 Posted December 27, 2011 Share Posted December 27, 2011 The 96 - 99 cars had a good spot right where the fuel lines come into the fire wall behind the drivers strut tower. There are 3 lines, but a plug in the firewall with 4 "nipples". Poke a hole in the empty one and feed the wire through. Man,had i known about that spot i would of stopped poking a hole through the grommet for the clutch (or brake) when i would run power for the Amps.. Link to comment Share on other sites More sharing options...
Rpm90001 Posted December 28, 2011 Author Share Posted December 28, 2011 I found a spot. Just below the clutch cylinder was an empty rubber plug. Poked a hole in it and ran the wire there. Ended up above the gas pedal. Worked perfect. I will tow with the Subaru for the first time tomorrow. Still very unhappy with how low the drawtite hitch sits. I have seen way better fitting hitch systems. Thanks for the help. Geo Link to comment Share on other sites More sharing options...
johnceggleston Posted December 28, 2011 Share Posted December 28, 2011 as long as it is tight and does not wiggle it will be fine. you are not hauling the queen mary. Link to comment Share on other sites More sharing options...
porcupine73 Posted December 28, 2011 Share Posted December 28, 2011 Right on, near where the clutch is/would be there is a nice large plugged hole. In the Subaru service manual, I did see one time where they mentioned using this hole as part of a diagnostic procedure. I think it was to run a transmission pressure gauge through it to be able to watch it while driving on the auto trans. Maybe that was the hole for the clutch pedal I am thinking of since mine's an auto. Link to comment Share on other sites More sharing options...
Rpm90001 Posted December 28, 2011 Author Share Posted December 28, 2011 I know Im not towing the Queen Mary, but it just looks horrible compared to other systems I have seen. Link to comment Share on other sites More sharing options...
porcupine73 Posted December 28, 2011 Share Posted December 28, 2011 Hm...yah it does kind of leave all its junk hanging out there doesn't it. Perhaps a small set of gold colored truck nuts would dress it up? Link to comment Share on other sites More sharing options...
Rpm90001 Posted December 28, 2011 Author Share Posted December 28, 2011 I think the the truck nuts would dress it up nicely..! Link to comment Share on other sites More sharing options...
johnceggleston Posted December 28, 2011 Share Posted December 28, 2011 RE: truck nuts i saw a large diesel pick up the other day with connecting rods and pistons hanging down off the hitch. it was a first for me. Link to comment Share on other sites More sharing options...
Redcap Posted December 29, 2011 Share Posted December 29, 2011 I think the the truck nuts would dress it up nicely..! I completely agree! Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 29, 2011 Share Posted December 29, 2011 Link to comment Share on other sites More sharing options...
Rpm90001 Posted December 29, 2011 Author Share Posted December 29, 2011 No that is a set of danglers... Link to comment Share on other sites More sharing options...
