Meeky Moose Posted March 17, 2004 Share Posted March 17, 2004 well the RX heater has never really worked well.. it blows fine, all 4 positions work, but the air is barely luke warm.. before i go tearin the heating ducts apart, anyone got any suggestions? no air bubble in the cooling system, car runs right below the half on the temp gauge. heater does warm up, but not even really luke warm.. if it does manage to get to luke warm, you can pull up to a light, stop, and it'll revert to cool air again.. i'm thinkin maybe a rats nest in the heater core ducting, but theres no fuzz comin out anywhere.. any ideas? Link to comment Share on other sites More sharing options...
rallyruss Posted March 17, 2004 Share Posted March 17, 2004 blend door not opening. check the control at the dash first then under the dash you go. Link to comment Share on other sites More sharing options...
thealleyboy Posted March 17, 2004 Share Posted March 17, 2004 Sounds like it could be low on coolant, based on the "start-stop" symptoms you describe. However, not likely if you've already checked for air trapped in the system. Malfunctioning air ducts is a good guess. Also, you cannot rule out the core itself as being gummed up. A backflush thru the core should eliminate or verify this possibility. good luck, John Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted March 17, 2004 Share Posted March 17, 2004 i drive with a plugged up core. i also live in wyoming. brrrr is right. some nights, i have to scrape the inside of the windshield while driving. the frost really builds up. i'm used to the cold by now. yopu know it's bad when you can see your breath the whole time. friends of mine will be shakin' and a shiverin' and i'm not really affected any more. Link to comment Share on other sites More sharing options...
All_talk Posted March 17, 2004 Share Posted March 17, 2004 Originally posted by MaroonDuneDoom some nights, i have to scrape the inside of the windshield while driving. the frost really builds up. i'm used to the cold by now. yopu know it's bad when you can see your breath the whole time. friends of mine will be shakin' and a shiverin' and i'm not really affected any more. Sounds like just about every winter day in a air cooled Volkswagen, but in my VW the wipers suck too, so you have to scrape the inside and outside while driving. These Subies are Soooo easy! Gary Link to comment Share on other sites More sharing options...
Sweet82 Posted March 17, 2004 Share Posted March 17, 2004 When ever I'm low on coolant I get the same thing..... However, you may not be getting any coolant type heating in your heater....? Let me explain. As I was taking out my heater and moving it to the buggy I noticed a wire that didn't make sence? I unscrewed the plug and wire only to find a heating element in my heater? I didn't realize Subarus had an electric heating element in the heater besides the coolant heating system. If it is weak heat, you may only be heating your windshield with the electric element and your other system is not working? Just a thought? Glenn, 82 Summer, with heater! 01 Forester, also with heater. Link to comment Share on other sites More sharing options...
Meeky Moose Posted March 18, 2004 Author Share Posted March 18, 2004 ok, get this one.. lol.. i knew the timing was off a little.. so i put a light on it last night.. turns out it was as 12 deg. so i set it to about 23.. (hard to tell on a lightened flywheel) the temp gauge reads that the car is acctually running cooler than it was, but the heat is hotter now.. haha explain that one.. has me stumped.. and the car pulled harder and faster when it was at 12 deg. too :-\ Link to comment Share on other sites More sharing options...
