rain_man_rich Posted December 28, 2011 Share Posted December 28, 2011 My loyale only has front speakers but appears to have been wired for rear ones as well. Anyone have rear speakers and where are they located? Rear door? Hatch? pics? Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted December 28, 2011 Share Posted December 28, 2011 If its a wagon, my GL wagon (pre-loyale, but same body) they were in the rear doors. Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted December 28, 2011 Share Posted December 28, 2011 The wiring and everything is there for the rears, in the rear doors. Just have to cut the door panel and mount them up. Make sure the window clears the back of the speaker. I'll have a set of 6 1/2s freed up from the legacy this friday if you want em for $20 or so. Quote Link to comment Share on other sites More sharing options...
rain_man_rich Posted December 28, 2011 Author Share Posted December 28, 2011 Thanks. I have a pair I want to try and fit first. If the magnet is too deep to clear I may take you up on yours. I was actually going to try and fit them in the hatch but since the wiring is already there in the doors I'll just keep it simple. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted December 28, 2011 Share Posted December 28, 2011 Thanks. I have a pair I want to try and fit first. If the magnet is too deep to clear I may take you up on yours. I was actually going to try and fit them in the hatch but since the wiring is already there in the doors I'll just keep it simple. If the magnet too deep, easy way to fix is piece of 1/2 inch or so plywood, cut a ring out and use the ring as a spacer behind the speaker.. Quote Link to comment Share on other sites More sharing options...
