Tire wear
opus
I had an inside wear issue when I had my 15" pugs on....
I went to an alignment shop, paid $39.95 and came out with perfect alignment. I had one low tire that they aired up so all of them sat at 33psi. Worked great.
Now Im back on 13s and I did tie-rods/wheel bearings and then went back, paid $39.95 again and I havent had a single bit of wear issues since.
Figure out what is wrong... check tie-rods, wheel bearings, axles, etc and see why you have an issue, if everything looks good and tight like it should be, then take it to Les Schwab or another reputable shop and get the alignment fixed.
