Engine swap 2.2 to 2.5
hkeller
yes, easy swap.
check the cam sprockets and if the trigger marks on the back are different swap the cam and crank sprockets onto the "new" engine.
should be installing with a new timing belt kit anyway so that stuff should be off anyway to get at the timing belt.
