drivers window goes down but not up.
I have a 2000 legacy sedan. The drivers window goes down but won't come up. Sometimes if you play with the switch you can get it up. So thinking it was the switch I got a used master switch from a on line parts supplier, put it in and same problem. Ran 12 v power to the motor and it works great in both directions. Did I get a bad replacement switch or is there a relay that's bad. What am I missing. Help.
I had this same issue on my 2000 Legacy Outback. I pulled the switch out and popped off the bottom cover. Under that you will see the bottom of the circuit board. There are 4 or 6 contacts for each switch, and in the case of mine, the solder for the drivers switch didn't look so great. I re-soldered all the joints and haven't had a problem since.
The same basic fix as the dash clock on the older cars.
Hope that helps.
