newgen85brat Posted December 30, 2011 Share Posted December 30, 2011 Okay, I am putting in a new clutch on my 85 BRAT, I bought a donor EA81 (322287) should be around an 83 engine. Both motors have the clutch packs still on them. Bought a BRAT clutch kit on line for 40 bucks (good name brand) Wrong size clutch disc, pressure plate and throw out bearing. I got upset thinking it was the guy I bought it from on EBAY so I ordered another from local parts house. Same issue. Why? I see an 8 7/8 inch disc but no pressure plate. What am I doing wrong. The parts guy could only find one set but could get a larger one but the throw out was not the press on bearing that I need. I read other threads and see others had questions but just wondered what it is that I am not seeing or doing right. The parts guy said he thought someone had switched it. Kind of strange both got switched?!.... Five guys work at the O'Reillys but I always get the guy I have to double check everything on? Of course everything needs ordered and it takes 3 business days to get. I eventually just had them order the throw out bearing by the numbers on it. The donor engine clutch was like new and the fingers show very little wear. I may just use the old parts. HELP and Advice please. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 30, 2011 Share Posted December 30, 2011 There's a huge mess lately with parts listings for the EA81 225mm kits. Exedy doesn't even list one in their catalog anymore. On Rockauto they list 4 kits that are correct: RHINOPAC/WORLD CAR Part # 15003 BRUTE POWER Part # 92225 BECK/ARNLEY Part # 0619131 ACDELCO Part # 381613 You can also use the EA82 pressure plate if you resurface the flywheel to the .815" step height (down from .906") and use a TOB from an 80's Nissan 720 truck. But you will still need the 225mm EA81 disc - which is a 21 spline, 22mm shaft size. GD Quote Link to comment Share on other sites More sharing options...
newgen85brat Posted December 30, 2011 Author Share Posted December 30, 2011 Thanks GD, why did two different clutches exist? Did one not work as well then was upgraded or did they always differ? Thanks for your help. Quote Link to comment Share on other sites More sharing options...
