palfer Posted January 1, 2012 Share Posted January 1, 2012 Changing the steering rack on my 97' OB Impreza and mixed up these bolts. One of these is for the steering yoke the other is for the front sway bar. I can't remember which is which. The shorter one has a tapered end if that isn't apparent from the picture. They are both 12mm. Thanks Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 1, 2012 Share Posted January 1, 2012 Pretty sure the one with taper is for the steering u joint. Whenever I remove parts that have multiple or similar bolts I put the bolts back in the hole they came from until I'm ready to reassemble. Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 1, 2012 Share Posted January 1, 2012 The tapered one is for the swaybar and the regular one is for the u-joint. Link to comment Share on other sites More sharing options...
