bstone Posted January 6, 2012 Share Posted January 6, 2012 I've definitely stalled my engine by pouring the seafom too fast. Just go really slow and it'll start to smoke. Then drive it around to block while smoking to be a good neighbor. Link to comment Share on other sites More sharing options...
starfox5194 Posted January 6, 2012 Author Share Posted January 6, 2012 Took Some photos. I saw two cracks in the knock sensor. There amount of contacts on the MAF sensor does not match up. I took a bunch so let me know what you see. The MAF sensor looked clean from what the human eye could see. That doesn't mean that there aren't microscopic debris on it. Right now, my money is on the knock sensor. Link to comment Share on other sites More sharing options...
jarl Posted January 7, 2012 Share Posted January 7, 2012 Man... that's a beauty... no visible rust! You have some serious leaks, though Those should have been addressed when the timing belt was done... Anyway... there are just two things catching my attention at this point (other than the oil mess and the apparently cracked knock sensor you already mentioned): - The the spark plug cables are not OEM (are they?). I don't know if that may affect the MPGs, but the collective brain seems to prefer OEM cables (or NGK, if I remember correctly) - The air filter looks very clean to have 50k miles on it. Still, I would consider replacing it to see if it's restricting the flow Other than that... I dunno. Try to measure the vacuum to see if there's a leak somewhere. I can't tell if the MAF needs to be cleaned... one of the local gurus may help you there. I don't think the mismatch in the number of pins is an issue. I saw you mention your tires are losing air quickly. If those are alloy wheels, consider having the tires re-mounted. That solved the problem in my OBW Link to comment Share on other sites More sharing options...
starfox5194 Posted January 7, 2012 Author Share Posted January 7, 2012 I was looking online for a knock sensor. This site looks sketchy. http://www.partsgeek.com/gbproducts/MC/394-07037594.html?utm_source=google&utm_medium=ff&utm_term=1990-1996+Subaru+Legacy+Knock+Sensor+Standard+Motor+Products+KS86+90-96+Subaru+Knock+Sensor+1995+1994&utm_content=MC&utm_campaign=PartsGeek+Google+Base&fp=pp&gbm=a Does anyone else have any better ideas? My advanced autoparts store would have to order the part. It's like 50$. Should I take the hit? Link to comment Share on other sites More sharing options...
The Dude Abides Posted January 7, 2012 Share Posted January 7, 2012 http://www.ultimatesubaru.org/forum/showthread.php?t=128092 Local member selling knock sensors. Link to comment Share on other sites More sharing options...
bork Posted January 8, 2012 Share Posted January 8, 2012 I was looking online for a knock sensor. This site looks sketchy. http://www.partsgeek.com/gbproducts/MC/394-07037594.html?utm_source=google&utm_medium=ff&utm_term=1990-1996+Subaru+Legacy+Knock+Sensor+Standard+Motor+Products+KS86+90-96+Subaru+Knock+Sensor+1995+1994&utm_content=MC&utm_campaign=PartsGeek+Google+Base&fp=pp&gbm=a Does anyone else have any better ideas? My advanced autoparts store would have to order the part. It's like 50$. Should I take the hit? I had a CEL, Used the Advanced auto knock sensor & no CEL now & more pep!There is a coupon link somewhere for $20 off at Advance. Link to comment Share on other sites More sharing options...
starfox5194 Posted January 8, 2012 Author Share Posted January 8, 2012 I'm going to take up the offer on the local member selling aftermarket knock sensors for 25$ suggested by the dude abides. Thanks! Link to comment Share on other sites More sharing options...
starfox5194 Posted January 9, 2012 Author Share Posted January 9, 2012 Just a little update incase anyone is curious. The new knock sensor was shipped today. I'm pretty excited for when it comes. Today I cleaned out my MAF with CRC MAF cleaner. It took like an hour due to my incompetence and a bolt that thought it would be funny to just disappear. But anyways I got to the MAF and sprayed it 10-15 times. I put the car back together and my heart stopped beating for a few seconds when my car wouldn't start. I tried my best not to panic and reconnected my battery's negative hookup. Luckily the car started. The smell of gasoline was a lot more prominent than before and my idle dropped to about 250 RPM. I blipped the gas and it seemed to be very ineffective. I let the car idle for about 2 more minutes. Blipped the gas again and all seemed well. reversed out of my driveway and drove around the block a few times. Car seemed to be running fine. Idle returned to 400 RPM. Acceleration in first and second seemed more effective. Could just be my mind though. Decided to listen to my engine as i revved it up to about 5K. It doesn't sound very pretty past 4K RPM. Do you think the knock sensor will play a role in this? Advanced auto parts listed O2 sensor for 100$ Anyone know where I could get one for cheaper. I'm looking for an OEM/non universal one. Obviously new. Link to comment Share on other sites More sharing options...
Olnick Posted January 9, 2012 Share Posted January 9, 2012 Advanced auto parts listed O2 sensor for 100$ Anyone know where I could get one for cheaper. I'm looking for an OEM/non universal one. Obviously new. Check the Bosch sensors on Amazon. Good quality product and the best prices I've ever found. http://www.amazon.com/gp/part-finder/slide-show/1995/Subaru/Legacy/ref=au_pf_pfg_s?ie=UTF8&Model=Legacy%7C64&Make=Subaru%7C13&Year=1995%7C1995&vehicleType=5&brand=&partsNode=15730891&carId=001 Consider the universal model--it's not difficult to wire up and saves a lot of money. Put one on my son's '92 Legacy and it's been great. Good luck. Link to comment Share on other sites More sharing options...
starfox5194 Posted January 10, 2012 Author Share Posted January 10, 2012 Just ordered the universal. I guess 35 is a lot better than 100 lol. And I'm good with wiring anyways. Link to comment Share on other sites More sharing options...
starfox5194 Posted January 12, 2012 Author Share Posted January 12, 2012 Oxygen Sensor came in the mail today. Thank god for amazon prime! I'm going to try to install it tomorrow. I think I might know where the upstream O2 sensor is because I've seen it when removing the muffler shielding to get to my shifter bushings. I'm just hoping that *is* the upstream sensor. I haven't ever looked for the downstream one so I'm not sure wether it's the upstream or not. I'd assume the downstream was farther down than the shifter linkage. Does anyone know what I'm talking about? I'll take photos tomorrow if I can't figure it out. I was looking at the photos on this site and I think I have the right sensor location. I'm not 100% sure so someone's reassurance. Incase you are unaware this is a 95 L outback with MT. Link to comment Share on other sites More sharing options...
jarl Posted January 12, 2012 Share Posted January 12, 2012 (edited) If your '95 looks like my '99, the front O2 sensor is the one right behind the passenger side axle. On my car the O2 cable is clamped to one of the engine mounting bolts and it's pretty obvious. The bulbous thing where it's mounted contains the front cat converter. The downstream O2 sensor (actually a "cat condition sensor") should be mounted... well, downstram Look for the cable, and follow it (IIRC above the 2nd cat) Edited January 12, 2012 by jarl Link to comment Share on other sites More sharing options...
starfox5194 Posted January 14, 2012 Author Share Posted January 14, 2012 I just did the Knock Sensor today. Took about 10 minutes because I couldn't get the thing unplugged lol. Anyways I put a few more photos on flickr near the end of my MAF after I cleaned it and the New knock sensor And such. I'm going to try to get my car on ramps and do the O2 sensor tomorrow. Link to photos: Link to comment Share on other sites More sharing options...
