mountainwalker Posted January 4, 2012 Share Posted January 4, 2012 This is one I’ve been wondering about for a while, though not related to any problem I’m aware of. After our 90K servicing, which is a major service, and which we did at the Subie dealer, we heard a bit more noise, and higher pitch noise (bit of a whine), whenever accelerating. The engine was just a bit louder and higher pitched. What would cause this, and is it something that needs attention? The car was quieter and smoother sounding before the 90K servicing. You would think it would sound smoother after the service. Car is a 2003 3.0 L H6 VDC Outback 2003 in excellent condition, at 105,466 miles. About to perform the 105K inspection and servicing, which is a minor servicing, during which we can look into the issue. Link to comment Share on other sites More sharing options...
Rooster2 Posted January 5, 2012 Share Posted January 5, 2012 Maybe new fan belts could cause this.......especially if over tightened?? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 5, 2012 Share Posted January 5, 2012 some possibilities; tabs on lower part of intake filter box not seated in slots (usually more of a whooshing sound) serpentine belt tensioner and/or idler pulley bearings going bad (known problem) air being sucked into PS pump at fitting on top that suction hose from tank is connected too. (known problem) Link to comment Share on other sites More sharing options...
ShawnW Posted January 5, 2012 Share Posted January 5, 2012 I think 1 lucky texan has it. "tabs on lower part of intake filter box not seated in slots (usually more of a whooshing sound)" Link to comment Share on other sites More sharing options...
mountainwalker Posted January 5, 2012 Author Share Posted January 5, 2012 Sounds more like a mechanical noise than a whooshing noise caused by air flow. Most likely a tight belt or idler pulley bearings. Could a belt stay tight like that for a year? Basically ever since the service the engine sound when accelerating is a bit higher pitched because of that bit of a whine, which does sound like it's related to a fan. What are the idler pulley bearings, and are they difficult/expensive to replace? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 5, 2012 Share Posted January 5, 2012 serpentine belt pulleys; http://www.subaruoutback.org/forums/110-gen-2-2000-2004/16823-h6-tensioner-bearing.html is it an automatic? you should also check the front diff fluid level. It's dipstick is on the passenger side down low. maybe the dealer just didn't get enough oil in there. Link to comment Share on other sites More sharing options...
mountainwalker Posted January 6, 2012 Author Share Posted January 6, 2012 Thanks, it's an automatic Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 6, 2012 Share Posted January 6, 2012 Well, something isn't right. Maybe they drained the front diff and forgot to refill? Does the whine seem to increase by the same amount as the increase in vehicle speed, or does it seem to increase 4x 'faster' than the vehicle speed? Dave Link to comment Share on other sites More sharing options...
Red92 Posted January 6, 2012 Share Posted January 6, 2012 I had a truck once (non-Subaru) that made more engine noise after a servicing... it turned out that the pulleys (crankshaft, alternator, A/C, etc) were slightly misaligned, and the old serpentine belt was quieter because it had worn down to accommodate the misalignment, masking the problem until I got a new belt. Just throwing that out as a possibility, but I'm not sure that this situation would persist for 15k+ miles... Link to comment Share on other sites More sharing options...
mountainwalker Posted January 6, 2012 Author Share Posted January 6, 2012 Dave, whine increases at same rate as acceleration. This isn't a very loud whine, it's subtle - many casual drivers would miss it, but I always pick up on the slightest change in a machine. Used to sound fully smooth before, and now it just has this subtle higher pitch whine - I'm fairly sure it's related to the fan. Link to comment Share on other sites More sharing options...
bork Posted January 7, 2012 Share Posted January 7, 2012 Someone else posted this & I also replied, because I have the same, mine sounds like a turbo, when accelerating, but I dont have a turbo. No one seemed to have an answer. Link to comment Share on other sites More sharing options...
mountainwalker Posted January 7, 2012 Author Share Posted January 7, 2012 The sound we have is so subtle that it would not be noticed except by someone who drove our car before the 90K service and who has a good ear. It's not serious. I'm sure it's a tight belt or pulleys related to the fan. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 7, 2012 Share Posted January 7, 2012 the radiator/AC fans are electric. My wife's OBW got a little quieter when i put synthetic fluid in the front diff. perhaps, if the dealership seviced the front diff, the previous owner had a heavier weight/'different' oil in there and the Subaru fluid is allowing it to sound a little louder. Or maybe they failed to top it up. Have you checked the front diff's fluid level? Link to comment Share on other sites More sharing options...
Mugs Posted January 7, 2012 Share Posted January 7, 2012 Someone else posted this & I also replied, because I have the same, mine sounds like a turbo, when accelerating, but I dont have a turbo. No one seemed to have an answer. 95-99 EJ22 cars had this problem...it was the air box design...customers complained enough, so in 2000 they baffled the crap out of the air box, and changed the filter location to the top of the throttle body. Personally I love the sound of the 95-99 accelerating...I always romp on it, just to make that "turbo" noise...then again I come with a weighted right foot. Link to comment Share on other sites More sharing options...
bork Posted January 8, 2012 Share Posted January 8, 2012 95-99 EJ22 cars had this problem...it was the air box design...customers complained enough, so in 2000 they baffled the crap out of the air box, and changed the filter location to the top of the throttle body. Personally I love the sound of the 95-99 accelerating...I always romp on it, just to make that "turbo" noise...then again I come with a weighted right foot. Cool! Resell the old boxes to the kids with the big fart cans on the exhaust tips! Link to comment Share on other sites More sharing options...
Mugs Posted January 8, 2012 Share Posted January 8, 2012 Cool! Resell the old boxes to the kids with the big fart cans on the exhaust tips! Ya but then you can't hear the turbo over the exhaust Link to comment Share on other sites More sharing options...
