Outback VDC 2003 OEM Alarm System problem or setting change?
Typically when we would open our car with the wireless key fob, the lights on the front and rear of the car would flash (apparently to help you see it in a parking lot). When we would get to the car, the red alarm light on the dash would be off already. About a month ago, whenever we opened the car with the wireless fob, the lights on the exterior of the car wouldn’t flash, and when we get to the car, the alarm light on the dash is still blinking, 2 rapid blinks followed by a pause repeating over and over. Car starts fine.
Is there a problem with the OEM alarm, or is it just a change in setting that needs to be reset?
i think it is in ''valet '' mode . sit in the car, open the drivers door and hold the unlock button for ~2 seconds.
hth.
It's, well, traditionally for if you're having your car valet parked, so that you don't give the valet the headache of setting off the alarm. Sometimes I go to valet mode in times where if it goes off accidentally it would be very inconvenient or draw unwanted attention.
