mountainwalker Posted January 4, 2012 Share Posted January 4, 2012 Typically when we would open our car with the wireless key fob, the lights on the front and rear of the car would flash (apparently to help you see it in a parking lot). When we would get to the car, the red alarm light on the dash would be off already. About a month ago, whenever we opened the car with the wireless fob, the lights on the exterior of the car wouldn’t flash, and when we get to the car, the alarm light on the dash is still blinking, 2 rapid blinks followed by a pause repeating over and over. Car starts fine. Is there a problem with the OEM alarm, or is it just a change in setting that needs to be reset? Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted January 5, 2012 Share Posted January 5, 2012 Typically when we would open our car with the wireless key fob, the lights on the front and rear of the car would flash (apparently to help you see it in a parking lot). When we would get to the car, the red alarm light on the dash would be off already. About a month ago, whenever we opened the car with the wireless fob, the lights on the exterior of the car wouldn’t flash, and when we get to the car, the alarm light on the dash is still blinking, 2 rapid blinks followed by a pause repeating over and over. Car starts fine. Is there a problem with the OEM alarm, or is it just a change in setting that needs to be reset? i think it is in ''valet '' mode . sit in the car, open the drivers door and hold the unlock button for ~2 seconds. hth. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 5, 2012 Share Posted January 5, 2012 Yes that sounds like valet mode. Quote Link to comment Share on other sites More sharing options...
mountainwalker Posted January 5, 2012 Author Share Posted January 5, 2012 You guys were spot on - thank you very much. I also found the instructions in the Subaru Keyless Entry booklet. Done. Only thing I'm puzzled about is - what's the use of Valet Mode? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 6, 2012 Share Posted January 6, 2012 It's, well, traditionally for if you're having your car valet parked, so that you don't give the valet the headache of setting off the alarm. Sometimes I go to valet mode in times where if it goes off accidentally it would be very inconvenient or draw unwanted attention. Quote Link to comment Share on other sites More sharing options...
