Jaimesbeam Posted January 5, 2012 Share Posted January 5, 2012 I took my 1995 Legacy 2.2 into the shop to get a muffler leak patched, and found out I also needed a new gas tank filler pipe (common problem I've heard), and that my CV boots were shot. Coincidentally NOW my CV joints are making some noise, which I hadn't noticed before. Now if I recall correctly from my antique VW days, you used to be able to get replacement CV boots that didn't require you to remove the shafts to replace the boots. EG split boots you could put around the CV joints without removing the shafts/joints. Am I dreaming or what? Do such thing still exist? Did they ever? In any case, it's probably too late for my current CV joints. My understanding is that your can drive them for quite a while longer, untill you get tired of hearing the noise, they aren't actually going to fail real soon? Thanks in advance for all your advise! Jim. Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 5, 2012 Share Posted January 5, 2012 Once they start making noise, it's too late. I don't replace axles with torn boots that aren't making noise. They get new Empi boots, grease, clamps and back into the car it goes! Link to comment Share on other sites More sharing options...
Red92 Posted January 5, 2012 Share Posted January 5, 2012 Now if I recall correctly from my antique VW days, you used to beable to get replacement CV boots that didn't require you to remove the shafts to replace the boots. EG split boots you could put around the CV joints without removing the shafts/joints. Am I dreaming or what? Do such thing still exist? Did they ever? You must be dreaming. The split boots on the air-cooled VWs were only for the swingaxle transmissions (spade axles with fulcrum plates as a universal joint), designed as easier replacements since it was so much work to pull the axles on those to replace the non-split boots that they normally had. Any ACVW with CV joints would have used non-split boots exclusively (IRS trans, for what it is worth). I don't think split boots were ever available for CV jointed ACVWs, probably because it was so much easier to pull the axles off. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 5, 2012 Share Posted January 5, 2012 I did try one of those split boots on a Honda 25-30 years ago. Didn't know they still made them. Didn't last a month. Link to comment Share on other sites More sharing options...
Jaimesbeam Posted January 25, 2012 Author Share Posted January 25, 2012 Ok, so split boots were a figment of my imagination... I alos seem to remember people pulling the CV joints out, and putting them in backwards/reversed to get more miles out of them? Apparently they only wear on one side? How hard is it to replace the CV joints on the 95 Legacy? Any special tools required? Bear in mind that it's winter in Maine, and I don't have a garage. But it's been above freezing during the day as often as it's been below *so Far*!!! thanks, Jim. Link to comment Share on other sites More sharing options...
idosubaru Posted January 25, 2012 Share Posted January 25, 2012 I alos seem to remember people pulling the CV joints out,and putting them in backwards/reversed to get more miles out of them? Apparently they only wear on one side? a guy on subaruxt.com, i can't recall his exact user name but his name is Wayne. he did that on his Subaru and it worked. he has a thread there about it. How hard is it to replace the CV joints on the 95 Legacy?Any special tools required? it's easy with good tools. the axle nuts can be insanely hard to remove. have an impact gun, torch, or 3/4" socket set available. i've sheared off multiple 1/2" sockets, breaker bars, and socket wrenches on axle nuts. i now have a 3/4" socket set and 900 ft/lb impact gun, it's easy. wrestling with that nut can mean the difference between 5 minutes and an hour. if you have any rust at all - just remove the top strut mount bolt, it's the only bolt you have to remove to remove the axle. loosen the lower bolt, remove the top one an the knuckle swings out enough to pull the axle off the trans first, thread it upwards towards the hood, then snake it out underneath. you have to mark the bolt head (not the nut) of the top bolt since it affects alignment. it's really simple, just mark it with something semi-permanent or permanent so you can resinllat the bolt in the same position and maintain alignement. with the wheel off you're only removing one bolt, one nut (axle nut) and loosening another to get the axle out. and knock the pin out. the axle pin holes only line up one way when reinstalling, take note, the pin won't fit if it's not the right way. self explanatory when you look at the splines int he shaft at each hole. it's not symmetric from one hole to the next. 30 minutes to swap one axle....plan on an hour or hour and a half for first time. that should roughly cover it. i get used Subaru axles with good boots for $25-$33 each and then reboot them. that's a great way to avoid the aftermarket axle junk and it's inexpensive too. Once they start making noise, it's too late. not that i recommend it or consider it good practice but i've personally rebooted noisy axles and haven't had issues with them yet. again, not saying i'd do it on someone elses car, one i'm selling, or even very often, but i've done it before and so far no issues. Link to comment Share on other sites More sharing options...
porcupine73 Posted January 25, 2012 Share Posted January 25, 2012 The axles are fairly easy to replace if some of the tips above are followed. A good 3/4" drive or larger breaker bar and socket is what I have been using. Then I put about a 5 foot long piece of 1-1/2" pipe over it and just lay on it. I have yet to find an axle nut that can resist that amount of force. No need to bother unstaking it. I have used an impact gun and that works fine too, but I saw somewhere Subaru said they didn't like impact for that application because of potential wheel bearing damage though the direction of the force doesn't seem like that would be an issue. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 25, 2012 Share Posted January 25, 2012 you might take a look through here; http://www.ultimatesubaru.org/forum/forumdisplay.php?f=45 Link to comment Share on other sites More sharing options...
mattocs Posted January 25, 2012 Share Posted January 25, 2012 I used a split boot on my Outback about 7 years ago. It lasted a few years until I got it replaced when the clutch was replaced. I got it at Advance Auto Parts. Link to comment Share on other sites More sharing options...
bork Posted January 26, 2012 Share Posted January 26, 2012 Dorman , had the split boots but I think they discontinued, but call them . I just did both inner boots, 1st time for me. Axle nuts came off with not much trouble. I wouldn't want to do outside where you are.Also, If your struts need replacing, now would be the time. BTW I called Gabriel shocks, & spoke to engineer, I asked if KYB makes the subaru fit Gabriels, & he confirmed yes. He also said many companies swap & trade & relabel shocks/struts. Cuts cost on tooling. Link to comment Share on other sites More sharing options...
nipper Posted January 26, 2012 Share Posted January 26, 2012 I used split boots as an emergency repair to get me home. PITA personally I think it is easier to replace the axle Link to comment Share on other sites More sharing options...
