subaruguru Posted January 6, 2012 Share Posted January 6, 2012 hey everyone the gfs hatch went into 3rd gear the other day and will not come back out any ideas on how to get it out? Yes i know "just swap in a 5 speed" that is the plan down the road but i am going away to school and can't do it right now but any help is greatly accepted. 1984 EA81 Hatch 4sp D/R bone stock never had any problems with the trans till now. Cheers R. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 6, 2012 Share Posted January 6, 2012 Slip the clutch and get it moving and you should be able to pull it out. Happens on the 4's from time to time. Tell her to always go to neutral when coming to a stop. GD Quote Link to comment Share on other sites More sharing options...
subaruguru Posted January 6, 2012 Author Share Posted January 6, 2012 Thanks GD i tried that still nothing though. I have tried all sorts of combinations to get it unstuck, pulling on the shift lever wile the car is moving, pulling on it while the clutch is in and the car is moving and not moving, pulling on it under load wile slowing down and accelerating still nothing. I am going to get under it today and see if the linkage is binding up. Cheers R. Quote Link to comment Share on other sites More sharing options...
fixingrusinc83 Posted January 23, 2012 Share Posted January 23, 2012 the fork for 3/4 has a pad that is 1/2 wide. When driving in 4th gear if you rest your hand on the shifter to quite down noise or just bad habit it wears the back edge off the pad it then uses the front edge of this pad to move slider into 3rd but the back off which is gone is what pulls it out out of 3rd and moves slider into 4th. Will need to be replaced if you can find one (requires splitting case) If you can drive and get engine to match tranny like shifting with out clutch it might come out shifting from 3rd to 4th good luck Quote Link to comment Share on other sites More sharing options...
man on the moon Posted January 24, 2012 Share Posted January 24, 2012 Transmission fluid is at an ok level? Quote Link to comment Share on other sites More sharing options...
petey Posted January 24, 2012 Share Posted January 24, 2012 Mines the opposite,it pops out of 3rd quite frequently lol Quote Link to comment Share on other sites More sharing options...
