Turboturd Posted January 7, 2012 Share Posted January 7, 2012 (edited) So I've been slowly chasing down problems in my ej20g swap. This last one is sorta stumping me. The computer flashes code 11 and won't leave limp mode. It won't rev easily,I've replaced the cam and crank from a junkyard car both measuring within spec on my ohm meter, I just checked the timing belt again and it appears to be correct. Does anyone have any ideas as to what may be causing this hesitation and limp mode? I'm gonna roatate the engine tomorrow and read the ac voltage, but that's about the last thing I can think to do. Edited January 7, 2012 by Turboturd Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 7, 2012 Share Posted January 7, 2012 I'm coming up with a crank sensor/harness issue. Check the connector where it plugs into the harness, check the wiring with an ohm meter from the pigtail where the sensor plugs in to the ecu plug. Also check all your grounds to make sure they're tight. Link to comment Share on other sites More sharing options...
Turboturd Posted January 7, 2012 Author Share Posted January 7, 2012 I'll check the harness tomorrow and make sure it's all good at least from the cam and crank. Is the only ground for these harness' the engine ground? I have that pretty well covered as it has a ground going from that straight to the battery. Is here no specific grounds for the ecu itself? Link to comment Share on other sites More sharing options...
Turbone Posted January 7, 2012 Share Posted January 7, 2012 Subaru's need grounds every where. Engine needs a grnd to body, battery needs grnd to body, ecu needs grnd to body, dash needs grnd to body......I could go on Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 7, 2012 Share Posted January 7, 2012 The actual ECU and associated sensor grounds are always on the manifold itself. But you still need a good path from there to the body and from the body to the battery negative. With swapped cars it's pretty hard to troubleshoot over the internet. Most people that aren't prepared to drag out the o-scope if something isn't right with a swap probably shouldn't be doing one. GD Link to comment Share on other sites More sharing options...
Turboturd Posted January 7, 2012 Author Share Posted January 7, 2012 (edited) GeneralDisorder said: The actual ECU and associated sensor grounds are always on the manifold itself. But you still need a good path from there to the body and from the body to the battery negative. With swapped cars it's pretty hard to troubleshoot over the internet. Most people that aren't prepared to drag out the o-scope if something isn't right with a swap probably shouldn't be doing one. GD Trust me when I tell you I've gone through the grounds, there's a ground from the battery to body, intake manifold, and starter mount. I'm still gonna keep checking grounds, but so far all the sensors I've checked have very good grounds and I understand how hard helping over the Internet is. I understand your assumptionins with me not using an o-scope yet, but I was really hoping it was something I have been overlooking. I've been working on this for a while, so I start to overthink the smallest problems. I'll check the outputs and see what I find, thanks. Edited January 7, 2012 by Turboturd Link to comment Share on other sites More sharing options...
MilesFox Posted January 7, 2012 Share Posted January 7, 2012 is the vss connected? Link to comment Share on other sites More sharing options...
Turboturd Posted January 8, 2012 Author Share Posted January 8, 2012 Yeah I connected it to what my Haynes manual says is the vss, I haven't driven it since I have connected it, so I have no idea if it is connected correctly. Would the vss affect running at idle? Thanks for all the help btw. Link to comment Share on other sites More sharing options...
