2004 2.5 SOHC torque specs and procedure
Looking at the bolts they are numbered as follows:
3 1 5
6 2 4
The torque sequence is as follows
1. torque all bolts in sequence to 21 ft-lbs
2. torque all bolts in sequence to 51 ft-lbs
3. in reverse order loosen all bolts 180 degrees
4. do step three again
5. Torque bolts 1 and 2 to 25 ft-lbs
6. torque bolts 3 -6 to 11 ft-lbs
7. torque all bolts in sequence 90 degrees
8. torque sll bolts in sequence 90 degrees
You are done.
Hope that helps.
Mike
