Suba_GL_87 Posted January 12, 2012 Share Posted January 12, 2012 someone people who dont have a engine hoist for Ej20 and Ej25 etc... so, im going tech you for replaced oil pan gasket... *only you need two mini floor jack lever and one of 3 ton jack hydraulic floor. *just removed four bolts between on the engine and automatic and get a out with the crow bar...replaced rear's main shift seal and oil pan gasket. put on the trans-axle for the jack, removed transmission and dont forget input seal ring. and do removed oil pan gasket use the cut off the board wood with two mini jack floor make you easy move and carries. :cool: huge Semi-automatic (3-foot long than EJ25's transmission) yep, we did try 2nd time for replace oil pan gasket in 3 days. Link to comment Share on other sites More sharing options...
