86 hatch ea81 timing question
due to the sluggish performance (22sec 0-60)
did some timing checking on my '86 hatchback
initial was 7 (corrected it to 8 which is not a big deal)
it climbs steadily with rpm increasing 9,10...20
but then all of a sudden when it passes aprox 2500 it jumps to what it would be 40 degrees (aprox. since there're no marks)
once again from 20 to 40 big jump once it goes over 2500
vacuum hose connected
any thoughts?
thanks in advance!
EDITED
finally bought timing light today =o)
it only does the timing advance jump from 20 to 40 degrees
only when i connect vacuum line
so, how do i bypass vacuum advance valve?
thanks
Edited by alexinvancouver
Hmmmm...
That`s unusual.
Centrifigual advance should be all in by 2000 rpm and should add about 12 degrees max.
Try it again w/the vacuum line disconnected.
Make sure the rotor is tight on the shaft.I`ve seen some flop around.
Check the shaft for play while you are there.
Edited by naru
+ shaft play
yeh, it could be around 2000 or just a bit over
i was watching the mark more than rpm's =o)
but it definitively jumps up
i had a timing light borrowed for one day only.
(don't want to buy one since i'm planning swapping the engine later anyways)
i'm gonna look closely into it when get back in a week.
going to monte-carlo next week to spectate first round of world rally championship!!! =o)
Turn the distributor shaft against the spring tension.If it turns much more than about 6 degrees, the centrifigual advance has problems.
Be sure to send us some rally pictures.
Edited by naru
change 12 degrees to 6, duh
unplug vac advance hose, plug hose with something while checking timing.
that is how it is done.
probably know that, but just in case, here it is.
for base timing sure
in the real world,removing the vac hose only makes a base timing difference if the idle throttle position is maladjusted or some comedian has it hooked up to manifold vacuum.
it doesn`t need plugging for as long as it takes to figure that out.
it doesn`t need plugging for the few seconds it takes to figure out wheteher the excess advance at rpm is related to the vacuum signal either.
Edited by naru
+ manifold vac.
  • 2 weeks later...
  • 2 weeks later...
