5MT D/R difficult to get out of 4hi
  xbeerd said:
rehashing an old thread,
i have a similar issue, hard to get out of 4wd once engaged, sometimes can roll it back and forth to get it easier. could it be something like a shift bushings at all?
4wd drives and functions fine, i have a 3.9 rear dif (cars '92), has to be forced out of 4wd, no clunking or anything when it shifts as the OP of this thread had.
so I have went to the practice of just using 4wd on snow or mud. dry/wet pavement still binds up and makes it difficult to get out of 4hi.
You'll find if you just reverse a couple of feet, push in the clutch and switch it to FWD, it won't be that difficult.
Also about the brake dragging, that's just the added resistance of having the entire drive-train engaged. You'll also notice that your acceleration is much slower in 4wd as well.
