ShawnW Posted January 19, 2012 Share Posted January 19, 2012 I can't seem to find the diagram on how to wire up the indicator light for the dash on an 83-84 wagon. The way I have it right now isn't right. The light comes on but wire gets warm and dash lights around it dim. Link to comment Share on other sites More sharing options...
redscab Posted January 19, 2012 Share Posted January 19, 2012 (edited) sounds like the circuit you are using to power it already has too much stuff on it or connections in that circuit are corroded causing more resistance for the whole circuit... is it a stock bulb? you might want to just look at the 3AT 4WD diagram to see what all is on that circuit, and see if there's a way to isolate the power and ground for it to see if it changes anything... Edited January 19, 2012 by redscab Link to comment Share on other sites More sharing options...
Gloyale Posted January 20, 2012 Share Posted January 20, 2012 Light has power to it already. Switch connects it through to ground. Link to comment Share on other sites More sharing options...
ShawnW Posted January 20, 2012 Author Share Posted January 20, 2012 The AT system has some sort of checker device in the instrument cluster but for the life of me I can't find it. 83 FSM says its on the back of the inst cluster with a wiper relay. Link to comment Share on other sites More sharing options...
