suburpy Posted January 20, 2012 Share Posted January 20, 2012 Hi All been awhile since I posted here, sold my ea81 wagon and bought a GF8 1994 WRX wagon (aussie model). I had some issue with the altenator light coming on so got a new one and that is now fine. In the process discovered the previous owner had removed the check engine light globe behind the dash. Now the CEL is staying on and I am getting five codes and would like some help with ideas to fix them Code 45 - Pressure sensor - was going to remove and clean solenoid with a bit of carby cleaner? Code 44 Turbo charging pressure control output signal )wastegate solenoid? - again a carby cleaner? Code 42 - Idle Switch - should I remove and clean it and clean uop throttle body Code 12 - starter signal - I replaced the main relay up under the dashboard as the previous owner had it in the car, apparently a know issue with this model Code 11- Crankshaft Position Sensor - pulled it and it has some physical damage amd ap[pear to be out of resistance specs Finally and the wierdest one Code 38 - ATCMM signal - i think this is to do with tourque control for automatics? This car is manual. This leads me to question wether the ECU is stuffed or someone tried to remap it and stuffed it. Happy to go through and check all these things but have a feeling they will still be in there when i put it all back togeteher and it will be ECU related - any comments thoughts welcome Link to comment Share on other sites More sharing options...
nipper Posted January 21, 2012 Share Posted January 21, 2012 It may be remapped, but first when you get that many codes you look for a common denominator. To me that would be the harness connectors or a bad weak ground. Since it is old enough I would run a new engine ground for the heck of it, then check all the connectors are clean and dry first. Link to comment Share on other sites More sharing options...
suburpy Posted January 21, 2012 Author Share Posted January 21, 2012 in regards to the 45 and 44 i noticed the waste gate solenoid has three vacuum hoses, the bottom one is not connected to anything and I presume that this not being connected is what is causing this code. My question is what should it connect too? Link to comment Share on other sites More sharing options...
nipper Posted January 21, 2012 Share Posted January 21, 2012 That I do not know as i am nto completly familiar with Turbos. Is there a vacume map on the inside of the hood? Link to comment Share on other sites More sharing options...
suburpy Posted January 21, 2012 Author Share Posted January 21, 2012 Thats a good suggestion to check the grounds. I noticed three ground points in the engine bay which i cleaned up, is there any particular ground points related to the ECU i should check ? inside the car? Link to comment Share on other sites More sharing options...
nipper Posted January 21, 2012 Share Posted January 21, 2012 NO but just for grins unplug the ecu then plug it back in. Inspect it for any loose female connectors in the plug. Sometimes the act of just unplugging/pluging it in cleans the terminals and issues go away. Link to comment Share on other sites More sharing options...
suburpy Posted January 21, 2012 Author Share Posted January 21, 2012 here is a photo of the current wastegate solenoid setup. I think the car was in an accident and it was not setup properly during repair Link to comment Share on other sites More sharing options...
suburpy Posted January 21, 2012 Author Share Posted January 21, 2012 Well a clean up of all connectors and grounds, diconnected battery for a few hours, cleaned ECU circuit board and Crankshaft sensor and now the only code i am getting is 35 which is purge control solenoid valve, given the mess in that side of the car it's no surprise that is the problem, can I use a purge control valve from a same era rex but an sti? Link to comment Share on other sites More sharing options...
