c0r3f1ght3r Posted January 21, 2012 Share Posted January 21, 2012 Is this possible? I've been thinking about this every time I pull my ebrake. I remember the first time I tried to slide the brat and realized the ebrake was pulling the front brakes and I was like wtf? Quote Link to comment Share on other sites More sharing options...
AKghandi Posted January 21, 2012 Share Posted January 21, 2012 If you search ebrake you'll find some write ups I believe you need the calipers from the rear of a Nissan 240 sx not sure on the year.. But since my wagon has rear disks already I'm going to add a hydro lock up for the rear. Should be pretty easy Quote Link to comment Share on other sites More sharing options...
Turboturd Posted January 21, 2012 Share Posted January 21, 2012 It been covered a lot. But more recent it's been discovered that calipers from the mid 80's accords work. Quote Link to comment Share on other sites More sharing options...
Cyfun Posted January 26, 2012 Share Posted January 26, 2012 Mid 80s Accord calipers supposedly work, but they're like $80 each. Probably better off getting 200sx or 240sx calipers and making a custom bracket that allows for better clearance of the ebrake mechanism. Quote Link to comment Share on other sites More sharing options...
Subruise Posted January 26, 2012 Share Posted January 26, 2012 calipers are cheaper @ pnp. also accords are way more frequent than 240s. locally at least. ya ya, used parts i know. rebuild? RV Quote Link to comment Share on other sites More sharing options...
tractor pole Posted January 26, 2012 Share Posted January 26, 2012 calipers are cheaper @ pnp. also accords are way more frequent than 240s. locally at least. ya ya, used parts i know. rebuild? RV Agreed, Accords are way more frequent because not everyone wants them to make "drift cars" out of them :-\. caliper rebuild kits can be had at a good local parts store or brake supply store for usually around $5 each side for a single piston caliper. I think I paid $5.40+ tax for the front kit I put on mu loyale. Ben Quote Link to comment Share on other sites More sharing options...
spazomatic Posted January 26, 2012 Share Posted January 26, 2012 really? mid 80s accord calipers will work on the rear? no mods for brake line or mounting? Quote Link to comment Share on other sites More sharing options...
Pooparu Posted January 27, 2012 Share Posted January 27, 2012 I did this Modification on my 1982 hatch. Quote Link to comment Share on other sites More sharing options...
Brock Samson Posted February 21, 2012 Share Posted February 21, 2012 what disc brakes will fit on the rear of my 1st gen brat Quote Link to comment Share on other sites More sharing options...
lyter1983 Posted February 22, 2012 Share Posted February 22, 2012 I'm doing a 5 lug swap on my 86 Brat. I have the rear hub assemblies(including backing plates) from an xt6. I'm trying to find out what caliper I can use that has an ebrake. I've read about people using the 200sx calipers mixed with the caliper bracket from an ea82t but will that work on the xt6 backing plates? Quote Link to comment Share on other sites More sharing options...
Turbone Posted February 22, 2012 Share Posted February 22, 2012 Yes, its the same setup I have on m 89 RX. Altho I havent got the ebrake cables routed or the handle installed yet Quote Link to comment Share on other sites More sharing options...
