hankosolder2 Posted January 23, 2012 Share Posted January 23, 2012 I have a '98 OBW 5mt with a '95 EJ22 swap, done about 5 yrs ago. My wife has been complaining of coolant odors lately, especially shortly after start up. I noticed the overflow bottle was a bit below the low mark... took a peek underneath (dark and raining out) and I think I see drops of coolant on the join between the head and block. Everything looks dry up top. Do these ever develop the external HG leak like the later sohc EJ25s? Nathan Link to comment Share on other sites More sharing options...
bstone Posted January 23, 2012 Share Posted January 23, 2012 hankosolder2 said: I have a '98 OBW 5mt with a '95 EJ22 swap, done about 5 yrs ago. My wife has been complaining of coolant odors lately, especially shortly after start up. I noticed the overflow bottle was a bit below the low mark... took a peek underneath (dark and raining out) and I think I see drops of coolant on the join between the head and block. Everything looks dry up top. Do these ever develop the external HG leak like the later sohc EJ25s? Nathan It's pretty rare that the ej22 develops a leak, but it can happen. I would get a few cans of the engine degreaser and thoroughly clean off the engine. Wait a day and then visually inspect it while the car is running. Also, top off the coolant and see if it still gets low. It may have just been due to the heater core being opened. Where in Chicago are you located? I am from there and work at a garage there in the summers. Link to comment Share on other sites More sharing options...
rverdoold Posted January 23, 2012 Share Posted January 23, 2012 I also had a similar problem with a 1991 2.0. In the end the radiator had a tiny leak spraying coolant over the engine. This could be smelled as well. In the end I had a broken radiator, thermostat and radiator cap. Link to comment Share on other sites More sharing options...
idosubaru Posted January 23, 2012 Share Posted January 23, 2012 most likely it's a leak from any number of other of places - hose, water pump, clamp, etc. with an unknown prior history and 15+ years on it there are other possibilities, though unlikely. Link to comment Share on other sites More sharing options...
johnceggleston Posted January 23, 2012 Share Posted January 23, 2012 i found some rust on a coolant pipe, where the heater pipe took from the crossover pipe, driver side rear above the head / block under the intake, on the last ej22 i swapped. i wire brushed and spray painted it orange, that was the only paint i had on hand. Link to comment Share on other sites More sharing options...
davebugs Posted January 23, 2012 Share Posted January 23, 2012 I vote probaby rad side thank or another plase where the rad is crimped. A lot of times the dye kit at the auto parts is money well spent rather than just throwing parts at things like this. Link to comment Share on other sites More sharing options...
hankosolder2 Posted January 23, 2012 Author Share Posted January 23, 2012 Thanks for your responses. I think I'm going to have to do some more inspection here. Unfortunately, I don't have a garage handy, so I'll monitor the coolant level closely and wait for a break in the weather or borrow a friend's garage. (Though I don't think anyone is going to volunteer the use of their garage for engine degreasing!) The water pump and all the hoses were replaced with OEM when I did the engine swap 5 years ago, so they _should_ be OK. Nathan Link to comment Share on other sites More sharing options...
bstone Posted January 24, 2012 Share Posted January 24, 2012 hankosolder2 said: Thanks for your responses. I think I'm going to have to do some more inspection here. Unfortunately, I don't have a garage handy, so I'll monitor the coolant level closely and wait for a break in the weather or borrow a friend's garage. (Though I don't think anyone is going to volunteer the use of their garage for engine degreasing!) The water pump and all the hoses were replaced with OEM when I did the engine swap 5 years ago, so they _should_ be OK. Nathan You can go over to the Marathon on the corner of Touhy and Western. They are open 24/7 and have mechanics there 24/7. They will let you rent one of the bays and use the lift for a very reasonable fee. I work there in the summers, doing the 9pm to 3am shift. At that time of night it's mostly brakes, oil changes, starters, alternators, and flat tires. Not much "major" work. Link to comment Share on other sites More sharing options...
hankosolder2 Posted January 24, 2012 Author Share Posted January 24, 2012 Thanks for the info! I might do just that. Link to comment Share on other sites More sharing options...
