danbennett2u Posted January 23, 2012 Share Posted January 23, 2012 Will an oil filter listed for an svx/tribeca fit on a first gen 2.2? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 23, 2012 Share Posted January 23, 2012 Hm....let's see Wix says 51334 for the 2.2L.....hm says the same, 51334 for the SVX. Hm actually Wix says the same thing 51334 for the Tribeca too. So we know the engine oil filter nipple is the same size and thread spacing. On the 90's 2.2L the limiting factor would be the diameter, if it is too large around it will hit the back of the timing belt cover. But it could be probably a good 8 to 10 inches long before length would be an issue. Quote Link to comment Share on other sites More sharing options...
danbennett2u Posted January 23, 2012 Author Share Posted January 23, 2012 Thanks, I had tried searching but couldnt find anything, will have to keep the wix site in mind for future. I figured they were the same since the SVX motor was based off of the ej22 Quote Link to comment Share on other sites More sharing options...
Durania Posted January 23, 2012 Share Posted January 23, 2012 Some info: http://forums.nasioc.com/forums/showthread.php?t=212470&highlight=h6+filter Why can't you just use a regular 2.2 filter? There is no possible gain going to come from using an H6 filter. Quote Link to comment Share on other sites More sharing options...
danbennett2u Posted January 24, 2012 Author Share Posted January 24, 2012 Because I got some for free Quote Link to comment Share on other sites More sharing options...
Durania Posted January 24, 2012 Share Posted January 24, 2012 Quote Link to comment Share on other sites More sharing options...
