subynut Posted January 23, 2012 Share Posted January 23, 2012 Those of you that like to turn corners fast in your EA82s, have any of you put a strut bar on the front and what year range of impreza did you go with? I've been searching around on here, Nasioc, RS25, and Subaruxt, but I cannot get any actual info as to which ones fit. Not to mention some say "do it" and others say "not worth it" which really confuses me. The front of the PandaWagon could use a little tightening with all my antics on the street and the increased RallyX/AutoX it's been seeing lately. Ideas? Thanks, Ted Link to comment Share on other sites More sharing options...
Quidam Posted January 23, 2012 Share Posted January 23, 2012 Those of you that like to turn corners fast in your EA82s, have any of you put a strut bar on the front and what year range of impreza did you go with?I've been searching around on here, Nasioc, RS25, and Subaruxt, but I cannot get any actual info as to which ones fit. Not to mention some say "do it" and others say "not worth it" which really confuses me. The front of the PandaWagon could use a little tightening with all my antics on the street and the increased RallyX/AutoX it's been seeing lately. Ideas? Thanks, Ted I haven't done this but if I did I'd triangulate the bar into the firewall as I know that would really stiffen things up. Just my .02, hey, let us know what you come up with and what you decide. Doug Link to comment Share on other sites More sharing options...
Numbchux Posted January 24, 2012 Share Posted January 24, 2012 I started looking into it. The strut top bolt orientation is slightly different. And the track width is narrower. You'll have to cut off the old spare tire support brackets that stick up. Redrill the plates on the strut tower, and cut down the brace. Keep these modifications in mind as you start looking at the different designs. I also heard that one for an RX7 (FC? I think?) would work with less modification. But I never looked into it. Also, look into fender braces. A tower brace is a help, but it is key to tie them into the core of the unibody. Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 24, 2012 Share Posted January 24, 2012 I've looked into using one for a newer Subaru and it just won't fit. Even the adjustable ones won't work. Only option is to make one or to find one to modify to work. Link to comment Share on other sites More sharing options...
subynut Posted January 24, 2012 Author Share Posted January 24, 2012 Thanks, guys. I'll check some of those ideas out. Ted Link to comment Share on other sites More sharing options...
ystrdyisgone Posted September 14, 2012 Share Posted September 14, 2012 I've been curious about this for my wagon as well. Did it ever get past the idea stage? Link to comment Share on other sites More sharing options...
subynut Posted September 14, 2012 Author Share Posted September 14, 2012 Sadly, no. Other things get me distracted and it gets dumped on the back burner for a while. Thanks for the bump. Once I have the exhaust done, I'll start working on it again. Link to comment Share on other sites More sharing options...
presslab Posted September 15, 2012 Share Posted September 15, 2012 I haven't noticed so much of a problem in the front; there's a fair amount of steel between the struts where the spare tire mount is. However the factory rally prep manual for the RX shows strut bar B0110GA054, so I'm sure it will only improve things. In the rear of my wagon however, the body twists so much that my rear gate rubs the body by the tail lights and it keeps rubbing the paint off. I think some kind of triangulated brace between the rear struts would be beneficial. Link to comment Share on other sites More sharing options...
