hush777 Posted January 24, 2012 Share Posted January 24, 2012 This is the wifes 87 gl-10 green dash not amber. Has been clicking in the dash for a few years, just wanted to know what I should check in there. Auto trans with cruise also. Hush Link to comment Share on other sites More sharing options...
AKghandi Posted January 25, 2012 Share Posted January 25, 2012 I also have a 87 Gl10 with the same dash is the dash doing anything weird? Speedo not working odometer not working something of that nature? Or is it just clicking? Link to comment Share on other sites More sharing options...
hush777 Posted January 25, 2012 Author Share Posted January 25, 2012 Clicking and the speedo jumps around a little (at 45 it jumps from 41 to 48 or so, been just going with the number that shows up most often.). Everything else works fine. Hush Link to comment Share on other sites More sharing options...
AKghandi Posted January 25, 2012 Share Posted January 25, 2012 its the speedo cable. it might have worked its way partially out or its probably just very worn and needs replacing. or the speedo assy. needs some lube... lol if you pull the gauge cluster out the problem should be easy to spot Link to comment Share on other sites More sharing options...
