Phase II EJ22 headgasket torque same as EJ25?
i had some EJ25 and EJ22 heads lying around, I couldn't tell a difference between the two. it did appear like one set had L22 and another L25 on them....that looks like 2.2 and 2.5 markings?
intake and exhaust valves are the same on Phase II 2's, how do the heads differ? cams probably...?
since the intakes will swap, a lot will be the same. did you compare the diameter of the combustion ring?
i overlaid multiple gaskets and couldn't tell a difference. maybe because they were all used gaskets or something and kind of trashed?
