Temp guage mod for EJ22 swap
Dj7291993
So, I've seen several times that if you want the stock temp gauge to work in a GL, you would need a resistor in parallel with the sender unit. Now, I'm not questioning your experiences, but I've got the resistance specs for the sender off Mitchell OnDemand, and they're almost exactly the same. So, shouldn't it work stock?
Specs:
87 GL - 154 Ohms = 104-122*F, 18 Ohms = 242-254*F
94 Legacy - 187.6 Ohms = 122*F, 19 Ohms = 248*F
I know the low side (temp) is different, but it's not to far off, plus the high side would effect gauge travel more. I ran the resistances for using a 275 Ohm resistor in parallel with the sender, and the values are way off. So, why in practice do you need a resistor, when in theory they should work about the same? :confused:
Your #'s are off.
perhaps you are getting stats for the FI temp sensor, not the gauge sender.
This is what the Subaru Factory manual says
88 GL:
72 Ohms= 158 F, 16.1 Ohms = 248 F
90 leagcy:
134 Ohms = 135 F, 19 Ohms = 248 F
These are directly from the Fuji service manuals. Section 6-2 body electrical.
Your #'s are off.
88 GL:
90 leagcy:
This is exactly what I thought too when I read his numbers. I know parts shops mix those up quite a bit.
Your #'s are off.
88 GL:
90 leagcy:
weird, i pulled those from acc, gauges, temp on mitchell. the fi one is a ptc, these are ntc, at least, that is what mitchell says. good to know.
also, sorry about my typing, my phones keyboard is being stupid.
The legacy one could correct #'s.......Hard to know excactly since they used a different temp for the lower spec.
The GL #'s are definately not right.
Parts info, and Service info for 80's subarus is notoriously inaccurate, mislisted, or just flat out wrong (torque to yeild head bolts in an EA82???:confused::lol::confused:)
Only Factory manuals can be fully trusted...and I've found a few misprints in them too:rolleyes:
