nipper Posted January 28, 2012 Share Posted January 28, 2012 I havent done one of these in a while. Since winter hasnt existed I am farther ahead then I planned. 1989 Justy 30,000 original miles CVT What's been done wheel cylinders calipers rotors brake fluid shoes and pads fuel pump drained tank of 8yo fuel (OMFG so vile) rubber fuel lines rebuilt carb (rotten rebuild so now a used one) Flush tranny (well its not really a flush as this doesnt have a torque converter) Timing belt (simple as it is how do I have it off one tooth) Tensioner Plugs Wires Cap Rotor Wiper Motor Horn Cleaned out a mouse condo from the heater Replace entire exhaust system Added a three stage cat in order to dump the air pump Battery Alt Belt Restored Body decals Restored all black trim parts Added: Right hand mirror External oil filter and engine oil cooler with a thermostat (weakest part of the engine is the oil system) Mech Oil Press Gauge (one under hood) Added two qts capacity to oil system Oil Temp Gauge Volt Gauge Alarm system (goes with the...) Power door locks - removed rear hatch lock cylinder and fixed dented area from repeated breakins - central locking Cruise Control Relay and wiring for later fog lights Second fuel filter Painted back panel between tailights Repaired minor rust (from sitting) Added 2003 SUbaru am/fm/wb/cd Added ipod/bluetooth interface To be done: Find miss (see timing belt) At least 1 tire (if not all four) Replace temp sensor - figure out why fan keeps short cycling Cruise - Trace the VSS signal and tap into - Get required minor parts to connect cable Connect door light signal for the alarm (easier said then done) - add rear speakers (may have to make custom mounts) Fix package tray (hello Mr fiberglass) Replace rear trim inside on tailgate Replace the ever popular fuel sending unit, 9 gallon tank it only reads one gallon Come up with a better idea for the gauges on the dash (fugly) Fix sunbaked paint Fix dent in left front fender (replace?) Figure out how to repair popped seams in the seats Anyone want to paint a fender for me Link to comment Share on other sites More sharing options...
TeamCF Posted January 28, 2012 Share Posted January 28, 2012 You've been busy! Link to comment Share on other sites More sharing options...
nipper Posted January 28, 2012 Author Share Posted January 28, 2012 I am so close. Actually not much got done this last summer due to either baking or swimming (weather). This is my hedge against gas and my "look I can park there!" city car. I just need to find the miss/stumble. My gut tells me I have the timing off a tooth, my brain says we couldnt have screwed it up as it is such a simple system Link to comment Share on other sites More sharing options...
ferox Posted January 28, 2012 Share Posted January 28, 2012 Pictures please.:cool: Link to comment Share on other sites More sharing options...
nipper Posted January 28, 2012 Author Share Posted January 28, 2012 I should do new picture set shouldnt I ? Link to comment Share on other sites More sharing options...
kanurys Posted January 29, 2012 Share Posted January 29, 2012 yes please Link to comment Share on other sites More sharing options...
nipper Posted January 29, 2012 Author Share Posted January 29, 2012 YOu may have to wait a bit. He is still on jackstands and is a mess inside. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 29, 2012 Share Posted January 29, 2012 We'll Wait. A neighbour has one Cherry Red Justy with CVT Transmission... those are Beautiful small cars, perfect for city driving. About the Miss, How old are the Sparkplugs? Kind Regards. Link to comment Share on other sites More sharing options...
nipper Posted January 29, 2012 Author Share Posted January 29, 2012 All new. I think I have a the tb off a tooth as the car has a poor idle, the miss is a 1-2-3 thing give it gas and it is better but still there, more like a stumble. I have checked the timing twice and it looks like it is dead on, but subaru being subaru they really arent generous with the refernce marks. The car has sat for many years so I am wondering if it is just from sitting. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 29, 2012 Share Posted January 29, 2012 From sitting it could have certain buildup on the Cyl and internals that might just dissapear with Continous driving, but by your Last description, it sounds to me like if the Li'l engine has some carburetor issue, such like Dirt on the air bleeds. Link to comment Share on other sites More sharing options...
nipper Posted January 29, 2012 Author Share Posted January 29, 2012 Carb hell. The 1st carb was full of this odd junk that was at some time called gasoline. Sent it out to be rebuilt. Came back clean but worse (and they left a freaking part out!). Anyone have a vent solenoid piston floating about? I am not the only person to get a crap rebuild on a justy carb so I was pissed but at least it wasnt just me. Put on a used carb from a running justy. Had to change the harness which required cutting the the main mix soloenoid. I could have opened the carb up to swap things over, but I wanted a carb from a running justy which meant not openeing it up to get a clue as to what is going on. Put the carb on, car fired right up, idles (sort of) runs etc. Idles well enough I can move it under its own power I dont think it is the carb, It may just need a good run around the block a few times, don't know. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 29, 2012 Share Posted January 29, 2012 ...a Good Run and Maybe a Seafoam Cleanup too. Kind Regards. Link to comment Share on other sites More sharing options...
nipper Posted January 29, 2012 Author Share Posted January 29, 2012 for some reason there is a difference between the 88 and 89 ncarbs, but couldnt find it in the FSM, so not sure if it is a real differnce or not. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 29, 2012 Share Posted January 29, 2012 I only recall, As Far as I can Remember the Difference is based upon the State's pollution laws... in example: Californian Justy's had the electronic feedback carb, instead the non-feedback; but I'm not completely sure about that information... Are the two carburetors made by the Same Brand Company? Link to comment Share on other sites More sharing options...
nipper Posted January 29, 2012 Author Share Posted January 29, 2012 Same mfg same brand same everything, except the 88 had a round plug, the 89 had a square one. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 29, 2012 Share Posted January 29, 2012 Well, I've noticed changes on the "Plug" only, between EA Subarus too... in example, my '85 Bumper lights had different plug (Roundie) than the 90's ones (Squarier). I Hope you will get rid of that miss easily, I Kindly suggest the use of a Seafoam can to help the Cleaning process, but you can try a Fuel additive too. Kind Regards. Link to comment Share on other sites More sharing options...
