lilredjusty88 Posted January 31, 2012 Share Posted January 31, 2012 i have a 1993 Loyale Sedan FWD with 140,000 on it and i think its got a bad #1 cylinder because when u pull plug wire off it makes no dif in the way the car runs. its shooting oil up thru the intake and out the mass airflow area, tremendous blow by, but yet the dang car will run still, and sometimes it runs like a mofo, did i mention it smokes horribly.. i recently had a problem with the throttle body to intake gasket that seals the water in the deicer portion of the throttle body, the gasket blew and dumped water in the oil, luckly i caught it right as it happend, maybe 5 to 10min elapsed, time enough to try to drive it out of the garage, and realize something wasnt right and then back in.. could it be thats potentially what caused the #1 cylinder failure?? i'm open to ideas and suggestions... :clap:BTW i got a 900$ 1992 Loyale wagon 4wd to replace the dead 1993 for the time being, WHAT A BARGIN!!!!! Link to comment Share on other sites More sharing options...
MilesFox Posted January 31, 2012 Share Posted January 31, 2012 oil in the intake and maf is probably due to clogged pcv valcve and or line. Spark plug wires can be finicky. Inspect the inside of the distributor carp. replaicng it may be your fix Link to comment Share on other sites More sharing options...
lilredjusty88 Posted February 1, 2012 Author Share Posted February 1, 2012 well sad to say i've already done the pcv system on it and it worked for about 20 or 30min then boom back to smoking and feeding off its self again.. its had a fresh tune up with everything... i don't know if i mentioned but awhile back i had a small instance with antifreeze and oil but it was quickly corrected. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 1, 2012 Share Posted February 1, 2012 If the PCV is the Problem because your engine has a Great amount of Blow-By, Why don't you install an Oil Catch Can? Also a New PCV valve could be a good option. Kind Regards. Link to comment Share on other sites More sharing options...
ivans imports Posted February 3, 2012 Share Posted February 3, 2012 the piston is broke between the compreshion rings verry comen if over reved rev it with the oil cap off and c if it blows smoke at the same time that # of cly is fireing Link to comment Share on other sites More sharing options...
zukiru Posted February 3, 2012 Share Posted February 3, 2012 ivans imports said: the piston is broke between the compreshion rings verry comen if over reved rev it with the oil cap off and c if it blows smoke at the same time that # of cly is fireing what?? try that again in english please. :cool: Link to comment Share on other sites More sharing options...
lilredjusty88 Posted February 4, 2012 Author Share Posted February 4, 2012 it is the #1 cylinder that is bad i believe not 100% but about 90% sure thats the one.. it blows smoke period with oil cap off. would a compression test tell me?? if so what should the average # be for compression test on healthy engine? Link to comment Share on other sites More sharing options...
