A/C Belt Idler Pulley '87 GL EA82 Engine
Have a carburated 1.8L, EA82, '87 GL WGN, 5SP Manual, 4X4 with A/C and power steering. Looking for an A/C idler pulley. Dealer and local parts houses don't carry them anymore and salvage yards here in the KC, MO area don't have much in the way of subarus, especially the type of subaru I am looking for. Any suggestions? Can the bearing can be replaced, hopefully without damaging the pulley - I don't have another pulley to fall back on? Can this engine be operated safely without the A/C belt if I don't run the A/C system? Can this engine be converted to a non-A/C engine? If so, where can one find the right bracket and dual v-belt pulley alternator? Have also read that some have forced lubricant into the bearing but no feedback as to how well that works long term. Input would be appreciated. Thank you.
Edited by sunflowersubaru
If this is it I can ship it to you. It has a snap ring inside and you can press the bearing out its an NSK 6202V bearing inside the pulley.
$20 shipped will toss in a bearing and a pulley assembly (shown) in a flat rate box. Phone number 720-440-1662 to order.
Here are some photos of my engine and the AC belt idler pulley.
Mounting bolts are the long hex shaped bolt on the left and the partially threaded-in bolt on the right.
When I spin the pulley I can hear it chirp, not short chirps but long chirps.
The number on the back side of the bracket looks like 773003, but the last digit is not completely clear.
Would like to pick up a spare idler pulley just in case.
In the mean time I will give NAPA a call re the bearing.
Thank you.
Went to NAPA and they had the bearing. NAPA shop attached to the parts store installed the bearing for not much. Installed and it runs quiet. Have an extra bearing also just in case. Doubt the car will last long enough to use it.
I'd still like to pick up an idler pulley just in case this one goes south and cannot be salvaged.
Anyone recognize the idler pulley in the photos?
Thank you.
Update
-2RS is a double sealed bearing
-2Z or -ZZ is a sheilded bearing and is not sealed. Grease is allowed to move (albeit slowly) from the sheilded bearing to the bearing pocket. Thus sheilded bearings can lose grease and can exchange grease and particulates with the bearing pocket.
And there is such things and -RS, and -Z; these bearings have a seal or a sheild on only one side. They are rarely seen in practice because most often they just sell the ZZ or 2RS and tell you to remove one side. I have also bought "open" bearings without seals and then been given -ZZ bearing and told to remove the sheilds and wash out the grease from the bearing :drunk:
  • 4 weeks later...
does anyone know the bearing part number for ea81 AC idler?
mine is shot.
