Brake light and battery light on simultaneously and intermittently
1993 legacy wagon. Brake light and battery light come on at same time and then go away and come back again seemingly randomly. I tested battery with engine off and it read 12.7 volts. With engine on, it read 14 volts, but periodically while idling, engine would make a light click noise and the voltage would quickly go down to 13 and quickly climb back up to 14. And when I turned engine off, voltage went back down to 12.7 but after only half a minute or so went to 18 and stayed there for roughly 10-20 minutes before returning to around 12.6. Any advice appreciated. Thanks.
