N8NQU Posted March 20, 2004 Share Posted March 20, 2004 1987 gl wagon 5 speed D/R it idles about 2000 rpm and when warm it does not come down,still 2000 rpm.can somebody tell me how to adjust the carb??? i would like to also adjust the low idle also????thanks in advance for the help from this board gives.Bill:wave: Link to comment Share on other sites More sharing options...
subiemech85 Posted March 20, 2004 Share Posted March 20, 2004 check choke kickdown, vac leaks, and gaskets pour mmo down carb to fog system clean use carb cleaner in tank, pour in at 1/2 tank or less, repeat 2x adjust idle speed with a LONG slot type cabinet screwdriver, it sticks out behind the ps pump, you'll know when you find it Link to comment Share on other sites More sharing options...
N8NQU Posted March 20, 2004 Author Share Posted March 20, 2004 i'll try the MMO and carb cleaner,is the screw that faces the spare tire???? i tried adjusting it and it did nothing.choke is working okay.Bill Link to comment Share on other sites More sharing options...
N8NQU Posted March 20, 2004 Author Share Posted March 20, 2004 Can somebody tell me where the cold( what is cold??? rpms) and operating temp idle is 700 rpm and do i do the cold first and then the warm?????Bill:wave: Link to comment Share on other sites More sharing options...
N8NQU Posted March 21, 2004 Author Share Posted March 21, 2004 Help?????:wave: Link to comment Share on other sites More sharing options...
Rossta86 Posted March 21, 2004 Share Posted March 21, 2004 check the slack in your throttle cable, if it is too tight it will cause your car not to idle correctly. Link to comment Share on other sites More sharing options...
N8NQU Posted March 23, 2004 Author Share Posted March 23, 2004 thanks on the reply,i'll look at the cable,i hope it's that simple.Bill:wave: Link to comment Share on other sites More sharing options...
subiemech85 Posted March 27, 2004 Share Posted March 27, 2004 the idle adj screw is on the front, by the ps pump on the left Link to comment Share on other sites More sharing options...
