jc50942 Posted February 5, 2012 Author Share Posted February 5, 2012 if it was up to me i would've already...but the boss is a cheap rump roast and someone told him it wasnt required...soooo no. But its gonna get done monday. Link to comment Share on other sites More sharing options...
jc50942 Posted February 11, 2012 Author Share Posted February 11, 2012 new chains...still missing on 1, 3, and 5...after it gets warm...leak down test was good...coils, boots, plugs all new....im outa ideas. Anyone run into this? Link to comment Share on other sites More sharing options...
nipper Posted February 11, 2012 Share Posted February 11, 2012 Compression test Link to comment Share on other sites More sharing options...
jc50942 Posted February 11, 2012 Author Share Posted February 11, 2012 already done Link to comment Share on other sites More sharing options...
nipper Posted February 11, 2012 Share Posted February 11, 2012 And the numbers? Are all these on the same side? Link to comment Share on other sites More sharing options...
jc50942 Posted February 11, 2012 Author Share Posted February 11, 2012 yep...all on the passenger side...so i was thinking maybe some kinda issue with the coils...which are also new...but something from the computer to the coils? Which doesnt make sense to me casue then it should do it all the time...not just after it gets warm. Link to comment Share on other sites More sharing options...
nipper Posted February 11, 2012 Share Posted February 11, 2012 Your digging too far right now. You have a set of coils working on the other side of the car, swap them and see if it follows. For it to be all three missing is something common to it. Soobys fire coils by going to ground through the ECU. I am not sure how the power feeds to the coils or how it splits if at all. Start by swapping coils, but to have one side work and the other ok (Still want the wet and dry compression numbers) it sounds like something is off a tooth. Even bent valves wouldnt be on all three on one side. Link to comment Share on other sites More sharing options...
jc50942 Posted February 11, 2012 Author Share Posted February 11, 2012 i honestly dont know what the numbers are...i didnt personally do the test myself....the shop foreman did while i was on another project. As far as the coils go...i did swap the coil from numer 1 and 2 to see if it changed anything...no change...possible injectors or that circuit? Link to comment Share on other sites More sharing options...
nipper Posted February 11, 2012 Share Posted February 11, 2012 Lets do a compression test. I have seen people say they were fine without really knowing what they mean. Pet peeve is "they were fine" and they didnt do a wet test. Link to comment Share on other sites More sharing options...
jc50942 Posted February 11, 2012 Author Share Posted February 11, 2012 im not arguing with you...im gonna do it myself...but what will a comporessing test prove that a leak down test wont..except give actual numbers...it no air leaks through anywhere when the valves are closed...then what is it that you are looking for? Like i said..not arguing...just learning from someone who obviously knows more than me. Link to comment Share on other sites More sharing options...
johnceggleston Posted February 11, 2012 Share Posted February 11, 2012 injectors? Link to comment Share on other sites More sharing options...
jc50942 Posted February 11, 2012 Author Share Posted February 11, 2012 injectors? yeh..injectors...i dont know about subies...but i know on gm's, if one is shorted, it will take that whole bank out because of the way they are wired. Link to comment Share on other sites More sharing options...
jc50942 Posted February 11, 2012 Author Share Posted February 11, 2012 i suppose i could either swap those too...or find out what they are supposed to ohm out at and check that....the thing that really gets me it that it feels smooth when its missing...almost like a false code....it was running really bad before i put the new chains in...im still getting the same codes but it runs smooth. Link to comment Share on other sites More sharing options...
nipper Posted February 11, 2012 Share Posted February 11, 2012 You are off a tooth, that is a dead giveaway, even with the H4 Link to comment Share on other sites More sharing options...
jc50942 Posted February 11, 2012 Author Share Posted February 11, 2012 i know for a fact that im not off...had it apart three times...after the new chains went in...lines the links up exactly as put forth in the service manual. Link to comment Share on other sites More sharing options...
nipper Posted February 11, 2012 Share Posted February 11, 2012 Show me the numbers of a compression test and prove me wrong. i want to get that off the list of possabilites before you look for gremlins. And also check to make sure there is power to the coils. Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 11, 2012 Share Posted February 11, 2012 Seems timing related. A compression test will show if the cylinder is building proper pressure. A leak down test may show minimal leakage, but it doesnt tell you if the valves don't open and close at the correct times. A compression check will tell you if the valves are opening at the right point to allow air in, and closing when necessary to build proper compression. Link to comment Share on other sites More sharing options...
nipper Posted February 11, 2012 Share Posted February 11, 2012 Thank you fairfax Each test has it s own ppluses and minuses. Even if the timing is off you can get a cylinder to pass a leakdown test. The compression test (wet and dry) will tell you if things are in synch. I am going to stand firm on timing as bent valves would have shown up on the leakdown. Do all 6 cylinders, wet and dry, and never rely on someone elses test data unless it is in writing. Link to comment Share on other sites More sharing options...
jc50942 Posted March 24, 2012 Author Share Posted March 24, 2012 ok...so i let the car sit for awhile...come to find out i dont have the right adjustment on the valves...so the heads are coming off...supposed to be .15 on the intake and .20 on the exhaust...i got .03 and .08 as an average between the three cylinders....good times.:-\ Link to comment Share on other sites More sharing options...
jc50942 Posted March 24, 2012 Author Share Posted March 24, 2012 im supposed to be pulling 17 inches of vacuum at this sea level and im only getting 13 so yeh...crappy...never thought to check to see what vacuum was...kinda makes me feel dumb. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 25, 2012 Share Posted March 25, 2012 Kinda depends on the cam profile I guess. On some engines if the lash clearance isn't exactly perfect it will run like crap. Others it doesn't make any difference if it's a little tight. On the Ej25d the exhaust valve lash clearance closes up because the valve face wears, but it runs perfectly fine right up until it burns the valve. Link to comment Share on other sites More sharing options...
jc50942 Posted March 25, 2012 Author Share Posted March 25, 2012 well..got the heads of..this is what i found on the intake side of the passenger side head. there is so much lip from the wear that i can even get the lifters for the number 1 cylinder out on the itake side....oh well...its only money Im just really suprised that there was no noise coming from that. Any that i could hear anyway. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 26, 2012 Share Posted March 26, 2012 Score! :-P Oil starvation is a beach. At least you caught it before the car was out on the highway somewhere on the side of the road with dangly bits of camshaft and timing cover/gears/chain. Link to comment Share on other sites More sharing options...
ivans imports Posted March 26, 2012 Share Posted March 26, 2012 Have two cores with good heads mine misfired because pistons were broke between ring lands. looks like ran out of oil on that one crank ok ? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 26, 2012 Share Posted March 26, 2012 where is that in the oil circuit? kinda makes me want to get a real oil pressure gauge - and glad I run synthetic. Link to comment Share on other sites More sharing options...
