87.5ea82txt Posted February 5, 2012 Share Posted February 5, 2012 I'm trying to set the timing on my 87.5 xt turbo and I'm having a hard time figuring out what I should be lining up here. I know the timing should be set at 20*BTDC, but I was thinking about setting it at around 18 or 19 to be on the safe side, since I've got alot more flow going on and sometimes boost hits about 11lbs. Will it make a difference if it's idling @700rpms or 1000rpms? Is there anything else I should do besides connecting the green connectors during this process? Quote Link to comment Share on other sites More sharing options...
zukiru Posted February 6, 2012 Share Posted February 6, 2012 The timing mark I used is on the flywheel under the rubber plug on the bellhousing Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 6, 2012 Share Posted February 6, 2012 Timing marks are on the flywheel or flex-plate. Those are the ones you want to use. Sometimes the crank pulleys don't have the pin that aligns them and they also have more play in them than the flywheel/flexplate has. GD Quote Link to comment Share on other sites More sharing options...
robm Posted February 6, 2012 Share Posted February 6, 2012 Aren't XT's a bit different? If EA82's are all the same, why does this one have that set of marks on the front pulley? Backing it off 2 degrees makes sense if you are going to overboost it. Still no guarantee the engine will survive the process, though. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted February 6, 2012 Share Posted February 6, 2012 Automatic cars don't have timing marks on a flex plate. They utilize the front crank pulley as shown. Theres usually a very small notch in the edge. It looks like you have it there near the 20 mark with the red dots near it. With the green connectors, it usually idles where its supposed to. Set it, drive it around, and verify its the same. Don't dig too far into it/over think it. Quote Link to comment Share on other sites More sharing options...
87.5ea82txt Posted February 6, 2012 Author Share Posted February 6, 2012 Thanks. Yeah, I saw that slight indent in the edge of the pulley, but I wasn't sure if it was put there intentionally. I'll pull the rubber bit after work and check it again from the flywheel to double check. Oh, and it Is a 5speed 4wd for what it's worth. Quote Link to comment Share on other sites More sharing options...
zukiru Posted February 6, 2012 Share Posted February 6, 2012 Its much easier to see the marks on the fly wheel if you have a manual. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 6, 2012 Share Posted February 6, 2012 Interesting - The '85 MPFI auto I just worked on has it's timing marks on the flex plate and doesn't have that whole front timing timing index. Well that's certainly strange then..... could it be an automatic *XT* thing? GD Quote Link to comment Share on other sites More sharing options...
Gloyale Posted February 6, 2012 Share Posted February 6, 2012 Interesting - The '85 MPFI auto I just worked on has it's timing marks on the flex plate and doesn't have that whole front timing timing index. Well that's certainly strange then..... could it be an automatic *XT* thing? GD It's a Spider intake thing. TB blocks clear view of the Flywheel/flexplate. 87+ XT MPFI cars used the timing marks on the front pulley. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 6, 2012 Share Posted February 6, 2012 It's a Spider intake thing. TB blocks clear view of the Flywheel/flexplate. 87+ XT MPFI cars used the timing marks on the front pulley. Ah - no wonder I haven't seen that. Never seem to see any XT's at my shop. GD Quote Link to comment Share on other sites More sharing options...
Quidam Posted February 6, 2012 Share Posted February 6, 2012 The pulley in the pic will have an extra hole drilled in it for a dowel/roll pin to insure it stays put so the timing marks won't change. Doug Quote Link to comment Share on other sites More sharing options...
naru Posted February 6, 2012 Share Posted February 6, 2012 I'm trying to set the timing on my 87.5 xt turbo and I'm having a hard time figuring out what I should be lining up here. I know the timing should be set at 20*BTDC, but I was thinking about setting it at around 18 or 19 to be on the safe side, since I've got alot more flow going on and sometimes boost hits about 11lbs. Will it make a difference if it's idling @700rpms or 1000rpms? Is there anything else I should do besides connecting the green connectors during this process? Yes.Use 700 rpm. Quote Link to comment Share on other sites More sharing options...
