EJ22 replace oil pan and leaky for twice times!?
i was replaced oil pan gasket and main shaft rear seal while i was removed automatic transmission.
when i was test starting for engine's on and there's badly as pour oil. i found it out there have bad sealant from rear oil pan gasket because i was put on rubber sealant on the both of gasket oil pan..
so, 2nd time same thing removed the automatic transmission and buy other Fel-Pro oil pan gasket. so, i put the sealant under the gasket on the oil pan before install it...BUT there still leaky like a dripping...
so, i just had a removed the transmission for my three times and tell me...
please tell me any advised for right way for replaced oil pan gasket OR just use the sealant on it without gasket...that's what Subaru's technology said? also i just buy new inch pound torque.
I've never used a gasket on an Ej oil pan. Always just use Ultra grey RTV.
Definitely check the separator plate on the back of the engine. That's a guaranteed to leak on an older engine.
Also if you didn't get the rear main seal from Subaru that could be leaking as well.
"so, 2nd time same thing removed the automatic transmission and buy other Fel-Pro oil pan gasket. so, i put the sealant under the gasket on the oil pan before install it...BUT there still leaky like a dripping..."
hello
you dont use a gasket on the oil pan for ej engine. you use ultra grey permatex and that alone...
hello, someody above said that , do you want to do this 3, 4 5 times. no gasket ok.
:D you bet
hello
Most likely you damaged the rear main seal.
Most advise not to touch the stock seal as they almost never leak.
Since you have changed the seal already, you need to confirm it's the source of the leak. If it is, remove it. Polish the crank shaft seal area with green and then gray scotchbright in a circular motion.
Lube the new seal lip seal and carefully drive it into the block. Make sure the lip seal does not roll or get damaged.
Ok, i would like to new thread abt question rear main shaft seal...
