floortom Posted March 20, 2004 Share Posted March 20, 2004 i've got a odd question, what is the best way to tighten the center nut in 3 steps, if #2 and 3 put the rocker shaft in the way? i cant get a socket on it. thanks. floortom. Link to comment Share on other sites More sharing options...
GLCraig Posted March 20, 2004 Share Posted March 20, 2004 There is a special socket for doing that. Link to comment Share on other sites More sharing options...
floortom Posted March 20, 2004 Author Share Posted March 20, 2004 what does it look like and how much is it? where do you get it? floortom. Link to comment Share on other sites More sharing options...
CIS Subaru Posted March 20, 2004 Share Posted March 20, 2004 When I did this, I used a method similar to the one in the Chilton's manual. They have instructions on how to make a spacer to put in place of the rocker arm assembly. I just used a couple of 1/2" drive sockets and large washers as spacers for the rocker arm nuts. Then, after you're all done torquing them all down (including the ones on the spacers), you remove your spacers, put the rocker assembly on, and torque its nuts again. I hope that made sense. It's really easy and saves you the trouble of buying a tool you'll hardly ever need. Link to comment Share on other sites More sharing options...
floortom Posted March 20, 2004 Author Share Posted March 20, 2004 the clouds have lifted., and grey matter has began to twitch. A vast flood of knowage has sweped over me! Thankyou guys! A long kept secret passed down to the palm of the incredabley stooopid! thanks again, floortom the feeble Link to comment Share on other sites More sharing options...
