wierd oil leak ?
goat
good ay
so l just did the oil seals and timing belts
(EA82)(92 loyale)
cuz of a massive oil leak
which is all good now
looks like l should have done the oil pump seals too
cuz there is a super minor leak which appears to be from there (though the oil level hasn't dropped according to the dip stick)
any way
thats not what this post is about
there is another leak
either out-of or on-to the passenger cv boot
it splatters on the fire wall and muffler (or whatever part of the exhaust system is right there)
but l can't figure out what it is or where it could be coming from :-\
my best guess is the transmission so l went to check the oil
and the dip stick is broken (the handle is there but not the dip part)
l'll get one when l get a chance
but for now could some one measure their tranny fluid dip stick to tell me how long it is and how far apart the fill lines are so l can check it
thanks
goat
well it does seem to have something to do with the cv joint
and l cleaned it and drove it and it seems to splatter from the cv joint
but the boot seems fine
l cant find a hole
and isnt the cv boot full of grease?
would it be melting or something?
also l would love to check the tranny fluid
but my dip stick is broken
hopefully some one will measure theirs
so l can aproximate
thanks
goat
Was the grease already there from a previously spit axle boot?
Maybe the axle was re-booted and a little overpacked with grease. Excess grease can work past the boot clamps. Try to clean it up and see of more occurs.
I wouldnt worry too much about the axle if the boot is not ripped, as it is worse for dirt and water to get in than for a little grease to come out
There's most likely a small hole or crack in your CV boot . I have one in mine and it's spits a little grease on the firewall and Cat ( catalytic converter ) . Squeeze the boot and listen for air coming out or like a slight whistle and move you car back an forth to find the hole . It's not really a big deal until you hear the joint start clicking when your driving .
CV boot is very likely. You should be able to tell by what's been slung onto the firewall and exhaust. Grease will be pretty obvious if you run your finger over it.
However, it could also be oil. A few weeks ago was riding with a friend in his Outback, smelled something burning. Peeked under, saw smoke comin off the cat right behind the CV. Figured it was a torn boot, but didn't see a tear. Then noticed that there was a bunch of motor oil pooled on top of the engine. Turns out he'd been adding some oil earlier and the wind had blown a bunch onto the engine.
So it's possible that there's an oil leak higher up, but it's probably the CV.
Edited by Cyfun
it does seem like axel grease
black and sticky
there was alot of it on the cross member
and l wasnt sure if it was from the previous oil leak
(got the car with the oil leak cuz the po didnt want to deal with it)
and l pressure washed it
the fire wall and cat stayed clean
till it got driven cross state
then then towards the end of the drive there were weird swishing sounds
and when l took a look new splatter
l'll look harder at the cv boot
(and probably ignore it til it starts making dry noises)
l dont know which tranny it is
5 speed manual
l'll look for numbers next time l get a chance (it's my lady's car now)
thanks
goat
Definitely sounds like CV grease then, probably that inner boot. Jack the car up so the CV is at a steep angle, and rotate it, looking carefully for a crack. Or it could be coming out of the end if it's missing a band.
yep cv it is
found the leak
cleaned it and attempted patching with RTV
we'll see if it holds
if not l suppose l'll try a split boot
any recommendations?
also
as per my other question about the missing trans oil dip stick
the numbers l found on the trans are as follows
464794
AW-TW75F5A2BV
so if soemone with the same trans would measure their dip stick and the fill lines
that would be great
thanks
goat
See if you can place something ...
Stabilize it... such that it is behind
the head and in front of the shaft.....
Like a piece firm card board.. wire it
in so it obstructs the shaft from the
head...
THe idea here is so you can determine
where this slop is spitting out.... Could
be the head gasket.. On the passenger
side.. the oil o-ring is on the fire wall
side of the head.... These love to squirt
oil out....
so the cardboard will get squirted on,
on the head side of the card board.....
and on the axle side it will be clean.
(if it is the o-ring in the head gasket)
if it is the axle, the axle side of the
cardboard will have the slop on it....
Yeah, and axle will sling grease out of
a tiny hole in a boot.( I got one doing
it right now)... and the head o-ring....
will shoot it out while driving.....
(like a spray gun)
Split boots are junk. A new boot is only about $10 and isn't horribly difficult to install. But I usually just replace the whole axle when I do, and get an axle with a lifetime warranty so that if the boot ever tears, whole new axle!
See if you have any luck with silicone or other patching methods. Maybe try a bike tire patch kit and glue, cause silicone doesn't always stick well to rubber. I've heard people have had luck just with vulcanized glue.
But if you're going to spend more than a few bucks trying to bandaid the problem, might as well replace the boot.
