coolskaterkid Posted February 9, 2012 Share Posted February 9, 2012 (edited) 93 legacy So last summer driving home from work, i go over a 9% precent grade. On the was home its down hill for about 9 miles, started smelling burning oil, pulled over checked oil it was nearly empty so towed it home The passenger side cam seal was completely pushed out of the block. So i replaced it and the other side, with new dealer cam seals. Now 6 months later same deal on the long down hill run, but this time the left side. So i think i have to much crank case pressure. I was told it could be the pcv, is that possible? If so where is it located? Also after this long down hill run, i get back on the road, and for about 1 mile it puffs large amounts of blue smoke, witch i believe is valve stem seals, as it never does it other then after the the long down hill coast, both my subarus do this. My ea 81 for about a half mile as the 2.2 does it longer. I can prevent it by coasting in neutral down the hill but that puts alot of strain on my brakes. So does this mean when coasting down hill, there is more back pressure on the motor, making crank case pressure increase? Edited February 9, 2012 by coolskaterkid Link to comment Share on other sites More sharing options...
nipper Posted February 9, 2012 Share Posted February 9, 2012 Means you PCV valve is stuck and needs to be replaced. Link to comment Share on other sites More sharing options...
coolskaterkid Posted February 9, 2012 Author Share Posted February 9, 2012 Thanks is it located on the intake? Link to comment Share on other sites More sharing options...
nipper Posted February 9, 2012 Share Posted February 9, 2012 Yes right side, screwed in, not hard to find. On more modern engines (1990 and better) they have gotten really tight. Pressure in the crankase can actually push out seals, cause oil consumption etc. Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 9, 2012 Share Posted February 9, 2012 When decelerating down hill the engine is pulling high vacuum for a long period of time and it sucks oil past the stem seals and past the pistons rings. Not gonna hurt anything. Just a typical trait of an older engine. If it starts smoking when driving normally, you drive it until it starts to foul the spark plugs, then replace the plugs and keep driving. :-p You do need to address the cam seal issue though. Coat the outer lip of the seal with anaerobic sealer before installing in the block to help hold it in place. Also be sure to check the Y fitting in the PCV hose that comes out of the block. Make sure it's not plugged up. And check the breather hoses that come from the valve covers for blockage. Link to comment Share on other sites More sharing options...
johnceggleston Posted February 9, 2012 Share Posted February 9, 2012 also check the hose s going to it, i have heard they can clog as well. Link to comment Share on other sites More sharing options...
coolskaterkid Posted February 9, 2012 Author Share Posted February 9, 2012 Thanks i will check all the blow by hoses for blockage. Funny thing i have gotten two notices that my registration was going to be suspended, if i didnt get a smog check, because someone reporting me to smoking vehicles, but i go into the ca smog check and i pass with average numbers, the smog guy just says they must have reported the wrong vehicle, oh well good old subi Link to comment Share on other sites More sharing options...
bork Posted February 10, 2012 Share Posted February 10, 2012 Thanks i will check all the blow by hoses for blockage. Funny thing i have gotten two notices that my registration was going to be suspended, if i didnt get a smog check, because someone reporting me to smoking vehicles, but i go into the ca smog check and i pass with average numbers, the smog guy just says they must have reported the wrong vehicle, oh well good old subi I think someone is jealous of your sube! Link to comment Share on other sites More sharing options...
coolskaterkid Posted February 10, 2012 Author Share Posted February 10, 2012 Ha yea, my wife followed me and said she could hardly see my car, good thing it only does it for a mile or so. lol, i replaced pcv today and cleaned the crankcase blowby lines, they had some gunk but not clogged. thanks for the help Link to comment Share on other sites More sharing options...
johnceggleston Posted February 10, 2012 Share Posted February 10, 2012 i had a dodge mini van that would smoke at start up. i was told it was the valve guides, oil leaking down into the cylinders after i turned the car off. i don't really know. i put 40 wt. oil in it and that helped a lot with the smoking. what would make an ej engine smoke at start up, and still be able to pass an emissions tests? Link to comment Share on other sites More sharing options...
coolskaterkid Posted February 10, 2012 Author Share Posted February 10, 2012 Same thing, the valve steam seals, in really bad shape letting the oil leak into the cylinders over night, luckily mine hasn't gotten that bad just the long down hill pulls the oil past them. Link to comment Share on other sites More sharing options...
