Hydraulic Rear e-Brake on my BumbleBeast!
OMG, I just had the best idea ever! Install a line lock solenoid for each individual brake. If you're in a situation where you're articulating or simply losing traction with certain wheels, you could activate those wheels' line locks to send the power to the other wheels! Manual traction control! Isn't that basically how ABS works, anyway?
VW's (the real ones not this front engine stuff) had each brake cable go to the handbrake. It was simple enough to add a kit that allowed to engage each emergency brake individually.
Yes that is how modern traction control works, but so does lightly applying the brake pedal.
Ah, I like those ideas of just attaching smaller handles to the existing one. Would mean destroying my tiny console, though. Another option would be to steal the mechanisms off of cars that have ebrake pedals. Then I could rig up a couple pedals on the left.
As far as the line-lock method, I would go the route where I would prevent pressure from reaching the wheel or wheels with good traction, so when I press the brake pedal, I'm only braking the slipping wheels. Then I could feather the brake, slow the spinning tire just enough so that I send some but not all the power to the wheels with traction.
Those foot operated brakes were horrible, and there is not enough room under the dash or braces for the assembly. Ideally you want to keep E/P brake cables as short as possible, as that reduces stretch. You can either destroy your dash or your console. If it was me I would go with the VW set up.
Another method would be to have two levers for left and right, and pulling would work the rear brakes, pushing would work the fronts. However I think I would rather have individual control of all 4.
Perhaps instead you could have more of a shift lever, where pulling straight back activates both rear brakes equally, but if you pull more to one side or the other, it pulls that brake cable more.
  • 2 months later...
The dream of many a passenger, to have their own brake pedal :)
My Wife's Dream too!... She always are "Braking" in the Passenger Seat when we are in the Caotic Traffic of the Big Cities, such like our Capital Twin Cities (Tegucigalpa and Comayagüela) or San Pedro Sula City.
(They have over one Million Population each.)
I am still carrying a Triangle-Shaped Solid Rock...
... I use a Rock :-p ...
best. parking. brake. ever. im dead serious if your wheels are chalked it aint going anywhere
Well...
Since I Already Dismissed the Idea of the Brake Lock, My Project now is to install a Rear e-Brake System.
So, I'll Need your advice in order to know:
- Which way is the more Reliable / Easy \ inexpensive to
- Retrofit / Swap \ Install that Rear e-Brake System.
That is for EA82 BumbleBeast Wagon, which Already has Rear Disc Brakes.
I Already reviewed this Thread:
http://www.ultimatesubaru.org/forum/showthread.php?t=63647
and Now I am Reading This other Thread:
http://www.ultimatesubaru.org/forum/showthread.php?t=128918
So I'm Almost Sure that it should be the Right Way to do my Project, but any advice will be Greatly appreciated.
Kind Regards.
Edited by Loyale 2.7 Turbo
  • 2 months later...
Just an Update:
Now my "BumbleBeast" Features an Excellent Rear e-Brake (Parking Brake) System. :headbang:
Forget the Hydraulic thing! ... it Features Cables, Lever and Calipers; to be a Fully Independent Brake System; to be Safer and Street Legal Again.
The Parts are Not expensive and Easy to find, plus the Install is Easy for those of us with Mechanical Experience. ;)
The Complete Writeup with Step by Step explanations, full of Guiding Pictures, could be Reached,
Here: ~► http://www.ultimatesubaru.org/forum/showthread.php?t=134321
I Hope this could be Useful.
Please, read it Complete to Understand the Why and How of that.
Kind Regards.
Excellent write-up! Been looking for something that clearly explains everything. I actually scored the rear disc brackets last weekend, but the discs on the donor car were too rusty to use. So now I just need to find some new discs and Honda calipers.
Except I want to rig my e-brakes up to be individually operated for traction control purposes. :)
Just an Update:
Kind Regards.
Nice write-up!
3 things. That doesn't look any easier than the Nissan option, except Nissans are far more common than old accords. Just make sure you use 240SX calipers, not 200SX, if you're not running XT6 rotors/backing plates. Also, I used Subaru Legacy handle and cables, no custom cables needed.
And, about cable routing. It's not an issue in your car, as it's FWD. But cutting holes, and having the cables drop down through the tunnel will cause clearance issues with the driveshaft.
That's how I did it in my Loyale, too, and the driveshaft would rub on the cables under hard accel. The next time I do it, I will run the cable straight back, and through the bulkhead under the back seat.
Nice write-up! ...
Thank you! ...
and You're Right, my Subaru BumbleBeast is FWD only and I Forgot about the Driveshaft, thanks for Remind it.
Kind Regards.
How about line lock / stage control / roll control, brake line solenoid valves used in racing, I'm sure they are tough enough for off road use.
Use one on each of the 4 brake lines, could be mounted anywhere along the lines, or easy bolt on adapt into existing fittings.
Wire it all to a control console, easy traction control. No messing with cables and levers, leave the stock ebrake as is.
http://www.jegs.com/c/Line-Lock-Roll-Control-Kits-Components/10159/10002/-1?sendroicid=bbef8492-2d00-41d6-b158-38db0de2603c&sendroiad=1769719539&sendroikwd=Line+Lock&gclid=CKCavaOp-bACFQxshwodNEi_jg
I agree for the reason of safety. .
But my point is, If by leaving the stock ebrake system intact, that the hydraulic idea is still good, but for another application, like traction control when crawling in difficult places.
Like the manual locker valve, then I thought of the solenoid ones, and having each line controled independently.
I think its worth trying, if someone has not already?
... leaving the stock ebrake system intact ...
That was the Reason to do an Rear e-Brake Retrofit: I Had to Got Rid of the Front e-Brake system on my Subie.
The Solenoids and Controls you Describe is Good Idea to Prevent the Wheels from Spin Free in 4X4 Rude use in hard Conditions, so you can Manually "Transfer" power to the ones that needs it.
Look on the Older posts of this same Thread for more information that has been already posted on that subject.
Kind Regards.
